嘉兆科技 功率探头 - PH2000系列
PH2000系列功率探头主要设计为配合PM2003使用。在功率测量设备中相比功率计而言,功率探头是更加重要的组件。功率探头将射频或者微波信号转化为电压信号,以便功率计处理。PH2000能在实际功率测量中做到与被测功率的良好阻抗匹配,避免了因阻抗失配引起的测量误差。
产品分类:仪器仪表 现场仪表
品牌:产品介绍
详细信息
PH2000系列功率探头主要分为二极管和热电偶两种,分别有50Ω和75Ω的标准输入阻抗。PH2000功率探头都具有精确的校准数据,并可作为NIST溯源数据。PH2000每个探头都配配备一个功率计接头和1.5m线缆。
型号 输出阻抗 输出接口 |
频率范围 |
动态范围 |
过载功率 峰值功率 CW功率 |
最大SWR |
偏移和噪声 |
频率 |
SWR |
偏移(典型值) |
噪声 RMS |
(典型值) 2σ |
二极管功率探头 |
PH2000 50Ω N(M) |
10 kHz to 8GHz |
-60 to +20 dBm |
1 W for 1μS 300 mW |
10 kHz to 2 GHz 2 GHz to 4 GHz 4 GHz to 8 GHz |
1.12 1.20 1.40 |
150 pW |
65 pW |
130 pW |
PH2001 50Ω N(M) |
100 kHz to 12.4 GHz |
-60 to +20 dBm |
100 kHz to 2 GHz 2 GHz to 4 GHz 4 GHz to 11 GHz 11 GHz to 12.4 GHz |
1.12 1.20 1.40 1.60 |
150 pW |
65 pW |
130 pW |
PH2004 50Ω N(M) |
100 kHz to 18 GHz |
-60 to +20 dBm |
100 kHz to 4 GHz 4 GHz to 10 GHz 10 GHz to 18 GHz |
1.30 1.50 1.70 |
150 pW |
65 pW |
130 pW |
PH2005 50Ω N(M) |
500 kHz to 18 GHz |
-70 to +20 dBm |
500 kHz to 2 GHz 2 GHz to 6 GHz 6 GHz to 18 GHz |
1.15 1.20 1.40 |
100 pW |
30 pW |
60 pW |
PH2006 50Ω N(M) |
500 kHz to 18 GHz |
-60 to +30 dBm |
10 W for 1μS 3 W |
1.15 1.20 1.40 |
100 pW |
30 pW |
60 pW |
PH2007 |
100 kHz to 18 GHz |
-50 to +30dBm |
10 W for 1μS |
100 kHz to 1 GHz |
1.07 |
1.5 nW |
.65 nW |
1.3 nW |
PH2008 50Ω N(M) |
100 kHz to 18 GHz |
-40 to +33 dBm |
10 W for 1μS 2 W |
100 kHz to 1 GHz 1 GHz to 2 GHz 2 GHz to 4 GHz 4 GHz to 12.4 GHz 12.4 GHz to 18 GHz |
1.07 1.10 1.12 1.18 1.28 |
15 nW |
6.5 nW |
13 nW |
PH2009 50Ω K(M) |
10 MHz to 26.5 GHz |
-70 to +20 dBm |
10 MHz to 2 GHz 2 GHz to 4 GHz 4 GHz to 18 GHz 18 GHz to 26.5 GHz |
1.15 1.20 1.45 1.50 |
100 pW |
30 pW |
60 pW |
PH2010 50Ω K(M) |
30 MHz to 40 GHz |
-70 to +20 dBm |
30 MHz to 4 GHz 4 GHz to 38 GHz 38 GHz to 40 GHz |
1.25 1.65 2.00 |
100 pW |
30 pW |
60 pW |
PH2011 50Ω N(M) |
100 kHz to 18 GHz |
-20 to +37 dBm |
100 W for 1μS 7W |
100 kHz to 4 GHz 4 GHz to 12 GHz 12 GHz to 18 GHz |
1.15 1.25 1.40 |
150 nW |
65 nW |
130 nW |
热电偶功率探头 |
PH2030 50Ω N(M) |
10 MHz to 18 GHz |
-20 to +20 dBm |
15 W 300 mW |
10 MHz to 30 MHz 30 MHz to 16 GHz 16 GHz to 18 GHz |
1.25 1.18 1.28 |
200 nW |
100 nW |
200 nW |
PH2033 50Ω N(M) |
10 MHz to 18 GHz |
0 to +37 dBm |
150 W 10 W |
10 MHz to 2 GHz 2 GHz to 12.4 GHz 12.4 GHz to 18 GHz |
1.10 1.18 1.28 |
20 μW |
10 μW |
20 μW |
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
