研扬 XTX-CV CPU 模块
2013/5/20 11:19:47
Onboard Intel Atom D2550/N2600 Processor Intel NM10 SODIMM DDR3 1066 Memory, Max. 4 GB 10/100Base-TX Ethernet CRT, Up to 24-bit Dual-channel LVDS LCD SATA 3.0Gb/s x 3, USB2.0 x 6, PATA x 1, SATA SSD (Optional) PCI-Express [x1] x 4, PCI x 4
产品分类:工控机 嵌入式系统
品牌:产品介绍
- Form Factor
XTX - Processor
Intel Atom D2550/N2600 processor
D2550: 1.86 GHz
N2600: 1.6 GHz - System Memory
204-pin DDR3 SODIMM x1, Max. 4 GB (DDR3 800/1066)
D2550 800/1066 MHz: Max. 4 GB
N2600 800MHz: Max. 2 GB - Chipset
Intel NM10 - I/O Chipset
Intel NM10 - Ethernet
Realtek RTL8105E, 10/100Base-TX - BIOS
AMI BIOS SPI type, 4MB ROM - Wake On LAN
Yes - Watchdog Timer
Winbond W83627DHG/PT, 255 levels - H/W status Monitoring
Supports CPU temperature monitoring - Expansion interface
32-bit PCI x4
LPC bus x 1
SMBus x 1 - Power Requirement
+5V only - Power Consumption
Intel Atom D2550 1.86 GHz, DDR3 2GB
3.94A @ +5V,
0.3A @ +12V w/ECB-910M
Intel Atom N2600 1.6 GHz, DDR3 2GB
2.46A @ +12V,
0.3A @ + 12V w/ECB-910M - Board Size
4.5" (L) x 3.74"(W) (114mm x 95mm) - Gross Weight
0.55 lb (0.25 kg) - Operating Temperature
32°F ~ 140°F (0°C ~ 60°C) - Storage Temperature
-40°F ~ 176°F (-40°C ~ 80°C) - Operating Humidity
0% ~ 90% relative humidity, non-condensing - MTBF
69,000
Display: Supports CRT/LVDS simultaneous/ dual view displays
- Chipset
Intel Atom D2550/N2600 processor integrated
DirectX 9, OpenGL *3.0
Integrateds hardware MPEG2 decoder - Memory
Shared system memory up to 512MB/ DVMT 5.0 - Resolution
Up to 1920 x 1200 for CRT
Up to 1920 x 1080 @ 24-bit for LCD (D2550)
Up to 1366 x 768 @ 18-bit for LCD (N2600) - LCD Interface
Up to 24-bit dual-channel LVDS
I/O
- Storage
PATA x1 (One device)
SATA 3.0Gb/s x 3
SATA SSD up to 16G (optional) - Serial Port
2 - Parallel Port
1 - USB
USB 2.0 x 6 - PS/2 Port
Keyboard x 1, Mouse x 1 - IrDA
One IrDa Tx/Rx Header - Audio
Mic-in, Line-in, Line-Out
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
