研扬 EMB-LN9T Rev.B工业母板
2013/5/21 10:24:48
板载Intel Atom N455/D525处理器 Intel ICH8M DDR3 667/800 SODIMM x 2, 最大支持4GB (N455最大支持DDR3 667) 双以太网 (千兆) VGA, 18位单通道LVDS或24位单通道
产品分类:工控机 嵌入式系统
品牌:产品介绍
- Form Factor
Mini-ITX - Processor
Onboard Intel Atom N455/D525 Processor - System Memory
204-pin DDR3 (667/800) SODIMM x 2, Max. 4GB (N455 supports DDR 3 667) - Chipset
Intel ICH8M - I/O Chipset
Winbond W83627UHG - Ethernet
Realtek 8102E for 10/100Base-TX, RJ-45 x 2 - BIOS
AMI Plug & Play SPI BIOS - 4MB ROM - Wake on LAN
Yes - Watchdog Timer
Generates a time-out system reset - H/W Status Monitoring
Supports power supply voltages and temperature monitoring - Expansion Interface
PCI x 1, Mini PCI x 1 , Mini Card x 1 - Battery
Lithium battery - Power Requirement
DC-12V - Power Consumption (Typical)
Intel Atom D525 1.8GHz, DDR3 1333 2GB
1.4A@+12V - Board Size
6.7" (L) x 6.7" (W) (170mm x 170mm) - Gross Weight
1.1 lb (0.5kg) - Operating Temperature
32°F ~ 140°F (0°C ~ 60°C) - Storage Temperature
-40°F ~ 176°F (-40°C ~ 80°C) - Operating Humidity
0% ~ 90% relative humidity, non-condensing - MTBF (Hours)
60,000
Display: Supports CRT/LCD, CRT/DVI simultaneous/ dual view display
- Chipset
Intel Atom N455/ D525 integrated
Integrates hardware MPEG2 decoder - Memory
Shared system memory up to 384 MB/ DVMT 4.0 - Resolution
Up to 2048 x 1536 (QXGA) @ 60 Hz for CRT (D525)
Up to 1400 x 1050 (SXGA)@ 60 Hz for CRT (N455)
Up to 1366 x 768 or 1280 x 800 (WXGA) for LCD & DVI - LCD Interface
18-bit single channel or 24-bit single channel - Video Interface
VGA, DVI-D
I/O
- Storage
SATA 3.0Gb/s x 2, CompactFlash? x 1 - Serial Port
RS-232 x 4, RS-232/422/485 x 1, optional extra RS-232 x 4 - Parallel Port
SPP/EPP/ECP mode - USB
USB2.0 x 8 - Digital I/O
Supports 8-bit (Programmable) - PS/2 Port
Keyboard + Mouse x 1 - Audio
Line-out, Mic-in, Line-in (选配), SPDIF (选配)
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
