Processor | Intel® Atom Cedarview D2550 (1.86GHz,10W) (Onboard) | |
Chipset | Intel NM10 Chipset | |
Memory | Supports 1 x 204pin SO-DIMM DDR3 1066MHz up to 4GB (Optional) | |
Storage | Supports 2.5″ SATA2 Hard Disk (Optional) | |
Graphics | Intel® CedarView Integrated Graphics Engine with GMA3650 Max Shared Video Memory up to 384 MB | |
Front Panel | 1*Power Switch with Power LED 1*HDD LED 4*COM 2*USB 1*LPT | |
I/O Ports | 1*DC12V IN 1*VGA 1*DVI-D 2*Gigabit LAN (Realtek RTL 8111E) 4*USB 1*PS/2 1* Line-IN/ Line-Out/MIC-In | |
Size | W:200mmD:260mmH:120.2mm | |
Extension | Supports 2 PCI Devices | |
Material | Aluminum | |
Power Supply | DC Adapter (90W) Input : AC100~240V1.5A50~60MHz Output : DC 12V 7.5A(MAX) | |
Environment | Temperature | 0~60 °C |
Relative Humidity | 10~95% @40°C,non-condensing |
下一篇:静电目标特性测试系统
