Shrick M30系列圆柱型电感式接近开关(DC二/四线型)
2013/6/3 15:10:05
外径30mm(圆柱型),直流二/四线型,齐平式安装检测距离10mm 非齐平式安装检测距离15mm
产品分类:离散传感器 物联网 接近开关 感知层 位置检测
品牌:施瑞克
Operating Vltage/工作电压 10-30VDC/5-36VDC/10-55VDC/10-60VDC
Switchig Frequency/开关频率 300KHZ,150KHZ
Response Time/响应时间 0.5ms/0.5ms,1ms/1ms
Operating Temperature/工作温度 -25°--+70°
Short Circuit Protection/短路保护 有
Repeat Accuracy/重复精度 <1.0%(Sr)
Switching Hysteresis/开关磁滞 <15%(Sr)
Max.Load Current/最大过载电流 200mA
Overload Trip Point/过载跳闸点 220mA
Protection Category/防护等级 IP67
Material Active Face/感应面材质 PBT
DC 4 Wire 10-30V Changeover PNP (N.O.&N.C.) SA1A1HOASC12
DC 4 Wire 10-30V Changeover PNP (N.O.&N.C.) SA1A1HOBSC12
DC 2 Wire 10-60V N.O.* SA1A1HOCOA12
DC 2 Wire 10-60V N.C.* SA1A1HOCCA12
非齐平式安装方式型号:
DC 4 Wire 10-30V Changeover PNP (N.O.&N.C.) SA1A1HRASC12
DC 4 Wire 10-30V Changeover PNP (N.O.&N.C.) SA1A1HRBSC12
DC 2 Wire 10-60V N.O.* S1C1B1805PO3A2 SA1A1HRCOA12
DC 2 Wire 10-60V N.C.* S1C1B1805PC3A2 SA1A1HRCCA12
Shrick KL2系列安全光幕
Shrick 高灵敏度矩形对射式光电开关
Shrick TZ1-822/866/867/868/869行程/限位开关
Shrick M12系列圆柱型电感式接近开关(模拟输出型)
Shrick SRK-SH-001立体车库人机界面/操作器
