产品选型
CLKTO IR Window for Indoor Medium Voltage Applications
Increase the safety and speed of electrical thermography
产品分类:
品牌:
福禄克
  概述
  Inspect your indoor switchgear safely with the latest IR Window from Fluke. If you are concerned about arc-flash or electrocution risk, this latest C-Range IR Window can help increase the safety of your personnel and reduce the cost of predictive maintenance, in compliance with indoor switchgear codes.
  特点
  ?Impact resistant viewing pane compliant to ANSI C37.20.2 for indoor switchgear up to 72 kV.
  ?CLKTO IR Windows from Fluke use the unique Quadraband? multispectral optic, allowing inspection with any camera for total flexibility both now and in the future.
  ?Certified by UL and CSA as suitable for Type 1 (Indoor) environment in North America, these C-Range windows are tested to withstand the long term aging effects of UV exposure.
  ?The CLIRVU® coating—exclusive to Fluke Windows—seals the optic prior to assembly to protect against moisture degradation.
  ?Own a Fluke Camera? The Quadraband? optic is IR-Fusion® compatible, allowing the thermographer to see potential problems in visual light and thermographic mode.
  ?The CLKTO IR Window incorporates a revolutionary, impact resistant viewing pane compliant with indoor switchgear regulations C37.20.2. For the first time, your Fluke IR Window allows visual inspection of your switchgear even with the cover closed.
  ?Identification plate attached for unique, onsite numbering for rapid location confirmation and faster repairs.
  ?Each infrared window comes complete with a security access key, installation instructions and self-adhesive drilling template.
  技术指标
Specifications
Optic data 3460611 FLK-075-CLKTO
Crystal inser t diameter 75 mm (2.96 in)
Viewing aperture diameter 68 mm (2.7 in)
Viewing aperture area 3632 mm2 (5.63 sq in)
Thickness 2 mm (0.08 in)
Shortwave IR, Midwave IR, Longwave IR, Ultraviolet (UV) capable Yes
Visual and fusion capable Yes
Maximum temperature Gaskets: 250 °C (482 °F)
Body: 659 °C (1219 °F)
Optic: 1400 °C (2552 °F)
Viewing pane 150 °C (302 °F)
Gaskets Low smoke and fume (LSF) compliant silicone
Pull-out strength Up to 630 kg (1388 lb)
Warranty Lifetime replacement against manufacturing defects
冶金行业轧钢线的温度监控
福禄克与京东工业深化战略合作
福禄克:勇敢探索,与世界较真
在线热像仪应用—过程监控
福禄克5560A 高性能多产品校准器——关键技术和功能
