HOKUYO日本北阳 AC-NHB4-Z 计数器
2013/8/19 9:49:32
通过计数器底部的滑动开关容易改变重置键锁定和计数速度
产品分类:低压电器
品牌:产品介绍
HOKUYO日本北阳计数器AC-NHB4-Z,DC-SAN, DC-NXA、 DC-NSA
白色LCD显示(LED背光)
7 位(7-段, zero-suppress), 重置显示, 溢出显示(能显示第8位)
重置键锁定
function that connects 12 pcs of 1-preset coun ter in parallel is provided.
built-in coun ter(12 pcs of coun ter, No.1 - 9, A, B, C) 可以通过前面板的键选择。
Output is one and is common use for 12 pcs of built-in coun ter(OR output) It can check "coun t-up" for each coun ter with characteristic
display.
It can be used as total coun ter by setting preset value to 0.
It can be prohibited to coun t by coun t-prohibition key in the front against unused coun ter
白色LCD显示(LED背光)
重置键锁定
display.
中国台湾KINTON精通接近开关感应器KX-W1
KUDOM库顿单相交流输出固态继电器KSI480D60-L
中国台湾TPC亚鸿接近开关JD-1705E1-C50
VMMORE微秒伺服驱动器ISD300-S25A-043
STUOB思拓邦圆柱形电感式接近传感器HX-1204-E1
