系统 |
| Intel Atom D525 1.8GHz (1MB L2缓存) 无风扇设计 |
| CFAST卡槽 x1 SATA插槽 x1 (适用2.5" HD) |
| 10/100/1000 Base-Tx RJ-45接口 x2, 10/100 Base-Tx RJ-45 connector with IEEE 802.3af standard PoE x4 |
| RS-232 x3, RS-232/422/485 x1 |
| Ear-phone, line-in, MIC-in |
| DC input 12~24V (2-pin电源接线槽或电源插孔) |
| 最高100W 最大2.88A (通常1.47A) @ 19V输入(含扩展卡 PoE) |
| Power x1, HDD/CFast x1, LAN x2 |
| 超时触发系统重启;Time-out时长设定有效范围:1~255秒 |
操作系统 |
| Windows XP, XP embedded, Windows 7 |
机械规格 |
| 190(W) x 240(D) X 82(H) mm |
工作环境 |
| 5 ~ 140°F (-15 ~ 60°C), 5 ~ 95% RH |
| -4 ~ 176°F (-20 ~ 80°C), 5 ~ 95% RH |
| FCC class B, CE EN55022 class B, EN55024, EN61000-3-2, 3 EN61000-4-2, 3, 4, 5, 6, 8, 11 |
| IEC60068-2-27 (50g peak acceleration) |
| IEC60068-2-6 (5g/10~150Hz/operating) |
嵌入式Windows 2009规格 |
| DHCP, IPv4, DNS, IPsec, HTTP, TCP, UDP, ICMP, IGMP, ARP, TAPI, TSP, SNMP, NTP, ICS, PPP, CHAP, EAP, Telnet, SNTP, FTP, SMTP, PPPoE, PPTP, NetBIOS |
| Windows command shell, telnet, FTP, web-based administration manager, wireless zero configuration |
| Telnet server, FTP server, IIS Web server, Dial-up networking service, COM Services, Disk Management Services, Remote Registry Service |
| Microsoft .net Framework 3.5 with service pack 1 Active Directory Service Interface (ADSI) Core Active Template Library (ATL) Certificate Request Client & Certificate Autoenrollment COM Base Common Control Libraries Common File Dialogs Direct3D DirectPlay DirectShow Distributed Transaction Coordinator (MSDTC) File-Based Write Filter (FBWF) Event Log Internet Explorer Mapi32 Libraries Message Queuing (MSMQ) Core Microsoft Visual C Run Time Libraries Registry Editor RPC Smart Card Cryptographic Service Providers Windows API Windows Media Player 11 Windows Script Engines WMI
| Audio, LAN, SysChip, VGA, Watchdog timer |
