技术 |
Wireless: IEEE 802.11a/b/g/n for Wireless LAN Ethernet: IEEE 802.11i Wireless Security
IEEE 802.3 for 10BaseT
IEEE 802.3u for 10/100Base-TX IEEE 802.3ab for 1000BaseT
IEEE 802.3at for Power over Ethernet IEEE 802.1D Spanning Tree Protocol IEEE 802.1w for Rapid STP
IEEE 802.1Q for VLAN Highest Data Rate: IEEE 802.11b: 11Mbps
IEEE 802.11a, g: 54Mbps
IEEE 802.11n: 300Mbps @ 40MHz
性能 |
5.8GHz Band:
FCC* : 5.725~5.850 GHz
CE** : 5.470~5.600 GHz; 5.650~5.725 GHz
2.4GHz Band:
FCC : 2.412~2.462GHz
CE : 2.412~2.472GHz (可为不同国家的规范定制)
802.11a/n: OFDM (BPSK, QPSK, 16-QAm, 64QAM)
802.11b: DSS (CCK, DQPSK, DBPSK)
802.11g/n: OFDM (BPSK, QPSK, 16-QAm, 64QAM)
802.11a: 17dBm@54M(5180MHz),16dBm@54M(5825MHz), 21dBm@6M(all);
802.11b: 21dBm@11M(all), 20dBm@1M(2412MHz),19dBm@1M(2484MHz);
802.11g: 19dBm@54M(all), 23dBm@6M(all);
802.11a/n HT20: 21dBm@MCS0/8(5180MHz),16dBm@ MCS7/15(5180MHz); 19dBm@MCS0/8(5825MHz), 14dBm@ MCS7/15(5825MHz);
802.11a/n HT40: 19dBm@MCS0/8(5190MHz),18dBm@ MCS7/15(5795MHz), 13dBm@ MCS7/15(all);
802.11g/n HT20: 21dBm@MCS0/8(all), 17dBm@ MCS7/15(all);
802.11g/n HT40: 21dBm@MCS0/8(2422MHz), 20dBm@ MCS0/8(2462MHz),16dBm@ MCS7/15(all);
802.11a: -82dBm@6Mbps, 1Rx; -95/-91dBm@6Mbps, 2Rx;
-65dBm@54Mbps, 1Rx; -79/-75dBm@54Mbps, 2Rx
802.11b: -82dBm@1Mbps, 1Rx; -95/-91dBm@1Mbps, 2Rx;
-65dBm@54Mbps, 1Rx; -91/-87dBm@11Mbps, 2Rx
802.11g: -82dBm@6Mbps, 1Rx;-95/-91dBm@6Mbps, 2Rx;
-65dBm@54Mbps, 1Rx; -80/-76dBm@54Mbps, 2Rx
802.11a/n HT20: -82dBm@MCS0, 1Rx; -95/-91dBm@MCS0,
2Rx; -64dBm@MCS7,1Rx; -77/-73dBm@MCS7, 2Rx
802.11a/n HT40: -79dBm@MCS0, 1Rx; -91/-87dBm@MCS0,
2Rx; -61dBm@MCS7, 1Rx;-74/-70dBm@MCS7, 2Rx
802.11g/n HT20: -82dBm@MCS0, 1Rx; -95/-91dBm@MCS0,
2Rx; -64dBm@MCS7, 1Rx;-77/-73dBm@MCS7, 2Rx
802.11g/n HT40: -79dBm@MCS0, 1Rx; -90/-86dBm@MCS0,
2Rx; -61dBm@MCS7, 1Rx;-74/-71dBm@MCS7, 2Rx
默认天线特性 |
界面 |
2x 10/100/1000Base-T, 自动协商
Eth 1 支持MESH 模式(2700-M)
2/4-pair UTP/STP Cat. 5 cable (100m)
网管 |
Web UI, Telnet IP Setup, DHCP Server/Client, 检索工具,SNMP,设置备份/还原,管理VLAN
状态: 系统,网络,无线,连线状态
系统: Bridge或Router模式
无线Hops: AP, CPE, WDS
无线MESH: MESH Gateway, MESH Point, MESH AP, Mobility Station
虚拟AP,SSID,无线Radio开启或关闭,SSID广播,VLAN ID,客户数,无线隔离
MESH ID, MESH mode, Channel, Max. Hops, Self- Healing Time, Ethernet Shortcut, Sync. Interval, Secuirty
20 bandwidth control setup
天线校准工具:Ping,Link Test,Site Survey,RSSI Caculator,First Fresnel Zone Calculator
安全 |
HTTPS, SSH, 802.1x, MAC Address ACL
WEP 64/128/152 bits, WPA-PSK (TKIP), WPA2-PSK/EAP (IEEE 802.1x/RADIUS, TKIP and AES)
电源需求 |
802.3at PoE (Eth 1)
DC Jack (12~48VDC)
JetWave 2710: max. 10W
JetWave 2720: max. 13W
JetWave 2730: max. 16W
(Maximum Radio Output)
机械规格 |
185 (H) x 75 (W) x 140 mm (D)
工作环境 |
通过认证 |
FCC part 15 Class B&C&E, EN55022 (Pending)
