IWF-2220工业级WiFi
定位于轻工业 & 企业应用,IWF 2220可支持0~+60℃操作,双无线电波,1个802.11b/g/n和1个802.11a/n (5GHz),最高支持2*300Mbps吞吐量。PA 和 LNA将其RF性能大大提升,使其无线覆盖面是正常SoC芯片下的4倍。
产品分类:无线通信 物联网 网络层 无线通信产品
品牌:集智达智能
IWF 2220
轻工业接入点,双RF, 双频段802.11a/b/g/n, 2/3dBi可拆卸天线孔
主要特点
采用新汉IWF控制器的隧道式AP管理
多个虚拟AP用于分组政策/管理
WDS 和 WES用于扩展无线覆盖面
双RF,用于IEEE 802.11b/g/n+802.11a/n , MIMO 2*300Mbps高吞吐量
双电源输入:802.3at PoE和12VDC输入
支持QoS & 802.11e WMM
工业级操作温度 -5~60℃
高性能RF分辨率解决方案@ 24dBm (最高值)
产品规格
无线电波 | Wireless Interface: IEEE 802.11b/g/n + 802.11a/n Radios operating in 2.4 GHz and 5 GHz frequencies Wireless architecture: (1) AP mode (2) WDS mode (Repeater/ Bridge) Modulation: (1) OFDM (64-QAM, 16-QAM, QPSK, BPSK) (2) DSSS (CCK, DBPSK, DQPSK) Channels: (1) USA: 1~11, 36, 40, 44, 48, 52~64, 100~136, 149~161 (2) Japan: 1~13, 36, 40, 44, 48, 52~64, 100~136 (3) Europe: 1~13, 36, 40, 44, 48, 52~64, 100~136 Data rate with auto fallback: (1) 802.11a: 6~54 Mbps (2) 802.11b: 1~11 Mbps (3) 802.11g: 6~54 Mbps (4) 802.11n: 6.5~300Mbps Transmit Power: (1) 802.11a: 21dBm@54Mbps ±2dB (2) 802.11b: 24dBm@11Mbps ±2dB (3) 802.11g: 21dBm@54Mbps ±2dB (4) 802.11n 5G HT20 & HT40: 20dBm@MCS7 ±2dB (5) 802.11n 2.4G HT20 & HT40: 21dBm@MCS7 ±2dB Receiver Sensitivity: (1) 802.11a: -70dBm@54Mbps ±2dB (2) 802.11b: -85dBm@11Mbps ±2dB (3) 802.11g: -70dBm@54Mbps ±2dB (4) 802.11n 5G HT20: -65dBm@MCS7 (5) 802.11n 5G HT40: -62dBm@MCS7 (6) 802.11n 2.4G HT20: -65dBm@MCS7 (7) 802.11n 2.4G HT40: -62dBm@MCS7 Detachable Antenna: 4x dual-band (2.4GHz & 5GHz) 2 x 2 MIMO in SMA Connector |
QoS-WMM | DiffServ/ TOS IEEE 802.1p/ COS IEEE 802.1Q Tag VLAN priority control IEEE 802.11e WMM |
切换 & 漫游 | IEEE 802.11i pre-auth (PMKSA cache) |
安全性 | WEP (64/128/152 bits) EAP-TLS + Dynamic WEP EAP-TTLS + Dynamic WEP PEAP/MS-PEAP + Dynamic WEP WPA (PSK + TKIP) WPA (802.1X certification + TKIP) 802.11i WPA2 (PSK + CCMP/AES) 802.11i WPA2 (802.1X certification + CCMP/AES) Setting for TKIP/ CCMP/AES key’s refreshing period Hidden ESSID support MAC Address filtering (MAC ACL) MAC authentication with RADIUS servers Maximum number of registered RADIUS servers: 2 |
系统管理 | Web-based administration SNMP v1/v2c Provides Event Log SYSLOG information support Statistics Configuration backup and restore Factory default setting restore Firmware upgrade Capable of performing RADIUS Accounting and Accounting Up date WES (Press-n-Connect) button for WDS Easy Setup Support Tunneled AP Management with secure WLAN controllers Support CAPWAP AP management Support IPv6 Ethernet LAN Port Mapping (with a NEXCOM controller) IGMP Snooping Proxy ARP |
内置服务器 &其他服务的客户端接口 | DHCP client DNS client SYSLOG client RADIUS client SNMP v1/ v2c client |
无线信号管理 | Number of ESSIDs (Virtual APs): 2x 8 Number of associated clients: 2x 128 Setting for maximum number of associated clients Network policy based on ESSID |
硬件规格 | Uplink Port: 1x 10/100/1000 Base-T Ethernet with IEEE802.3at PoE (as PD) LAN Port: 4x 1x 10/100/1000 Base-T Ethernet Antenna: 4x RP-SMA foldable antenna Antenna gain: 2/3dBi @2.4/5GHz |
外观和电源 | Support IEEE 802.3at PD Form factor: wall mount Dimension (WxDxH): 213 x 125 x 37.4mm (not include antenna) Weight: 828g (AP include wall mount, not include antenna nor adapter) PoE input: 802.3at DC Jack: +12V/2A |
运行环境 | Humidity 95% @ 60℃ (non-condensing) Operating Temperature 0~+60℃ Storage Temperature: -20~80℃ Vibration: Random 0.3g |
认证 | FCC, CE RoHS compliant |
包装 | IWF 2220 x1 CD-ROM (with User’s Manual and QIG) x1 Detachable antenna x4 Ethernet cable x1 |
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
