SWF-1210工业Wi-Fi安全网关
当下,多数自带设备(BYOD )和嵌入式设备由于缺乏正确、有效的网络安全保护,常常会受到网络威胁。针对这一问题,为了向所有连接设备、装置提供一个安全、可靠的WLAN通讯环境,新汉最新推出了一款安全的AP——SWF 1210,集成了DPI(深度包检测)扫描引擎,以保护基于传统PC的设备和非PC的嵌入式设备,免受网络安全威胁。
产品分类:无线通信 物联网 网络层 无线通信产品
品牌:集智达智能
SWF-1210主要特点
· IEEE 802.11b/g/n 模式的AP, 300Mbps高吞吐量的2T2R
· 集成5种应用的安全解决方案
· 后台签名数据库更新较快
· 反病毒(AV): 病毒扫描,包括HTTP/ FTP/ SMTP/ POP3/ IMAP4协议
· 网络维护: 积极过滤恶意网站(560K+条数据)
· 入侵防御(IPS): 带有2,600+条签名的入侵扫描
· 应用维护 : 可配置的应用程式管制,包括1M和P2P
· 网络过滤: 可自定义关键词URL过滤(35个预定义类别)
产品规格
无线电波 | Wireless Interface: IEEE 802.11b/g/n Radios operating in 2.4 GHz Wireless architecture: Tx Power (2.4GHz): Rx Sensitivity (2.4GHz) Antenna: 2x RP-SMA Connector, 3 dbi antenna gain |
接口 | Uplink Port: 1x 10/100/1000 Base-T Ethernet LAN Port: 4x 1x 10/100/1000 Base-T Ethernet USB 2.0 x1 Power switch |
管理 | NTP based or manual time setting HTTP/HTTPS based Web GUI Configuration Profile Management Internal ramdisk based syslog server or external syslog server SNMP v1/ v2c Support Multiple SSID |
网络 | WAN: DHCP client/ Static IP/ PPPoE LAN: Static IP/ Mask and integrated DHCP server Router/ Bridge/ WDS Mode Network address translation Policy based routing Dynamic DNS Normal or hiding SSID Wireless Security: No Encryption/WEP/WPA/WPA2/802.1x Basic IPv6 support Popular 3G/ WiMAX/ TD-LTE dongle support thru USB (conditional) |
防火墙 | SPI (Stateful Packet Inspection) Firewall Access Control List Universal Plug and Play Port Forwarding Port Triggering |
VPN传递 | IPSec pass-through L2TP/ PPTP pass-through |
标题 | Blowfish, 3DES, AES encryption support Routing and Bridge mode support UDP and TCP OpenVPN support 3 Authentication method: password, RSA key, or both |
反病毒(AV) | High Performance Streaming Anti-Virus Engine Packet-Based and Low Latency Scanning HTTP/ FTP/ SMTP/ POP3/ IMAP4 Generic TCP Stream Scanning for other TCP flows Destroy popular Windows/ Linux/ Android virus, Trojan, spyware Default AV signature capacity could capture more than 32 million new virus/ Trojan instances Signature rules could be renew by signature database Renew frequency is about 1~2 up dates per day |
网络保护(WG) | HTTP based attacks prevention from popular malicious websites Fine granularity for domain/path, not only domain Supporting URL keyword based blocking. For example, “sex” keyword for blocking website which contains this keyword in its URL. Automatic up date via NEXCOM signature file distribution cloud Default WG signatures can block 20K newest malicious website URLs |
入侵防御系统 | High performance streaming intrusion prevention engine Packet-Based and Low Latency URL normalization Protocol Anomaly Traffic Anomaly detection and blocking Port scan detection and blocking Actions: drop packet/drop session/log |
应用程序保护(APG) | High performance streaming application classification engine Packet-Based and Low Latency Fine granularity. For example, MSN messenger login, chat, file transfer, audio/video are selectable. Facebook or Facebook flash game are selectable. Application Guard whitelist Scheduled application control-For example, allowing MSN chat after office hours. Default APG signature can identify 400 applications |
网络URL过滤 | 35 categories for web URL filtering Querying backend database support 174 million categorized web page Natural Language Processing technology assisted categorization (Keyword base ) Advanced Trend Tracer technology to catch the buzzwords Support 48 languages |
VPN Type and Connection | IPSce: Site-to-Site, Remote Access, and Remote Access (XAUTH) PPTP: Server OpenVPN: Server/Client Site-to-Site GRE: site-to-site L2TP: Server/Client, L2TP, and IPsec |
外观和电源需求 | Form factor: wall mount Dimension (WxDxH): 213 x 125 x 37.4mm Weight: 716g (AP include wall mount, not include antenna nor adapter) DC Input: +12V/1A |
环境 | Humidity 95% @ 60℃ Operating Temperature -5 ~60℃ Storage Temperature: -20 ~80℃ Vibration: Random 0.3g |
认证 | FCC, CE RoHS compliant |
包装 | SWF 1210 x 1 CD-ROM (with User’s Manual and QIG) x 1 Power adapter Detachable antenna x 2 Ethernet cable x 1 |
保修 | 捆绑1年保修服务,用于签名库更新 项目可提供相应年限的保修服务 |
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
