东电化兰达 FPS系列单体式电源
2014/4/15 14:12:11
FPS系列单体式电源
产品分类:工业电源 开关电源
品牌:东电化兰达
FPS SERIES
Single output 1000~3000W
Features
No.1 in the world on power density.
1000W max. AC-DC front end Power Supply packaged on 1U rack size.
| ●FPS3000 3 modules of FPS1000 with 1U shelf. (Max.3kW) ●FPS1000-□/P Front IEC inlet : optional model (Size WxHxD : 127 x 41 x 294mm) |
Specifications(technical data download)
Model | FPS1000-48 | FPS1000-24 | FPS1000-12 |
Nomimal output voltage | 48V | 24V | 12V |
Output voltage adj.range | 48V to 58V | 21.5V to 29V | 10.5V to 13.2V |
Nomimal output current | 21A | 40A | 72A |
Maxmam output power | 1008W | 960W | 864W |
Input voltage/frequency range | 85~265VAC continuous /47Hz~63Hz | ||
Efficiency(Typ) | 88/88% at 100/200VAC maximam out put power | 84/86% at 100/200VAC maximam out put power | 81/83% at 100/200VAC maximam out put power |
Protection | Over curent protection ,Over voltage protection , Over temrature protection | ||
Front panel LED | AC OK(green) ,DC OK(green) ,DC FAIL(red) | ||
Operating ambient temperature | 0~ 50�C (By internal fans. Variable speed control) | ||
Dimensions(W x H x D mm) | 127 x 41 x 290 | ||
Interface | I2C Interface bus : optional model[/S] | ||
Front IEC inret | Front IEC inret :optional model[/P] (stnadard :rear connector) |
车规MOSFET技术确保功率开关管的可靠性和强电流处理能力
2023年制造业“开门红”,抢滩大湾区市场锁定DMP工博会
2023钢铁展洽会4月全新起航 将在日照触发更多商机
