东电化兰达 PAH75D系列电源模块
2014/4/15 14:34:41
Dual output DC-DC module 75W
产品分类:工业电源 线性直流电源
品牌:东电化兰达
PAH-75D SERIES
Model name | |||||||||||||
Option
Features
Half-Brick Dual output DC-DC module
Wide input voltage range : 3676VDC
Operating base plate temperature range : -40 100
Conduction coolingWide Option
ON / OFF logic ( Positive/Negative)
Over voltage protection (Auto reset/Manual reset)2 year warrant
Specifications(catalog download) (technical data download)
Model name | PAH75D24 | PAH75D48 | ||||||||||||||||
3325 | 5033 | 2518 | 3318 | 3325 | 5033 | |||||||||||||
Output voltage | Vo1 | Vo2 | Vo1 | Vo2 | Vo1 | Vo2 | Vo1 | Vo2 | Vo1 | Vo2 | Vo1 | Vo2 | ||||||
3.3V | 2.5V | 5.0V | 3.3V | 2.5V | 1.8V | 3.3V | 1.8V | 3.3V | 2.5V | 5.0V | 3.3V | |||||||
Output current | 15A | |||||||||||||||||
Input voltage range | DC1836V | DC3676V | ||||||||||||||||
Maximum output power | Po1 Po2 =60W | Po1 Po2 =75W | Po1 Po2 =45W | Po1 Po2 =50W | Po1 Po2 =60W | Po1 Po2 =75W | ||||||||||||
Output voltage range | 10% | 10%, -0% | 10% | 10%, -0% | 10% | |||||||||||||
Line regulation (*1) | 6.6mV | 10 mV | 6.6 mV | 6.6mV | 10 mV | 6.6 mV | ||||||||||||
Load regulation (*2) | 16.5mV | 25.0 mV | 16.5 mV | 16.5mV | 25.0 mV | 16.5 mV | ||||||||||||
Cooling | Conduction cooling (Heatsink & airflow has to be chosen according to instruction manual) | |||||||||||||||||
Operating temperature |
Withstand voltage | Input-output : 1.5kVDC, input-baseplate : 1.5kVDC for 1min. | |||||||||||||||||
Safty standard | Built to meet UL1950, CSA950(C-UL), EN60950(BSI) | |||||||||||||||||
Fanctions | Over voltage protection, Over current protection, Thermal protection Option : Positive ON/OFF logic , Auto reset Over voltage protection |
*1 | DC24V Input | 1836VDC WITH RESPECT TO NOMINAL INPUT LINE 48V;CONSTANT LOAD; BASEPLATE TEMPERATURE= 25 |
DC48V Input | 3676VDC WITH RESPECT TO NOMINAL INPUT LINE 48V;CONSTANT LOAD; BASEPLATE TEMPERATURE= 25 | |
*2 | NO LOADFULL LOAD WITH RESPECT TO 50% OF MAX LOAD; OTHER OUTPUT:NO LOAD;CONSTANT INPUT VOLTAGE; BASEPLATE TEMPERATURE= 25 |
Product lineup
Model name | CH | Output voltage | Output current | Output power |
PAH75D48-2518 | CH1 (Vo1) | 2.5V | 15A | 45W |
CH2 (Vo2) | 1.8V | 15A | ||
PAH75D48-3318 | CH1 (Vo1) | 3.3V | 15A | 50W |
PAH75D48-3325 | CH1 (Vo1) | 3.3V | 15A | 60W |
CH2 (Vo2) | 2.5V | 15A | ||
PH75D48-5033 | CH1 (Vo1) | 5V | 15A | 75W |
CH2 (Vo2) | 3.3V | 15A |
车规MOSFET技术确保功率开关管的可靠性和强电流处理能力
2023年制造业“开门红”,抢滩大湾区市场锁定DMP工博会
2023钢铁展洽会4月全新起航 将在日照触发更多商机
