Image | Type | Output | Dimming Mode | Panel Size (inch) | Output Connector | Model | Specification |
Input Voltage (V) | Output Open Voltage (Vrms) min. | Output Current (mArms) typ. |
| On-board Type | 1or2 | Non- Dimming | 3~8 | Pin terminal | CXA-L10A | 5 | 800 | 5 |
CXA-L10L | 12 | 800 | 5 |
CXA-P20L-L | 12 | 800 | 10 |
3~10 | CXA-M10A-L | 5 | 1000 | 5 |
CXA-M10L-L | 12 | 1000 | 5 |
CXA-M10M-L | 24 | 1000 | 5 |
| Connector Type | 1 | Non- Dimming | 3~15 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-L0505-NJL | 5 | 1400 | 5 |
CXA-L0512-NJL | 12 | 1400 | 5 |
CXA-L0524-NJL | 24 | 1400 | 5 |
| Connector Type | 1 | Current | 3~15 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-L0605A-VJL | 4.5~5.5 | 1600 | 6~2.9 |
CXA-L0612B-VJL | 9.6~14.4 | 1500 | 6~1.6 |
CXA-L0712-VJL | 9.6~15 | 1500 | 7~2.5 |
CXA-0490 | 10.8~13.2 | 2200 | 6~3 |
CXA-L0624-VJL | 20~28 | 1400 | 6~3 |
SM02B-BHSS-1- TB(LF)(SN) / JST | CXA-L0605A-VSL | 4.5~5.5 | 1600 | 6~2.9 |
CXA-L0612B-VSL | 9.6~14.4 | 1500 | 6~1.6 |
CXA-0499 | 10.8~13.2 | 2200 | 6~3 |
CXA-L0624-VSL | 20~28 | 1400 | 6~3 |
PWM | 3~8 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-0489 | 10.8~13.2 | 1200 | 6~2.9 |
3~15 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-0461 | 10.8~13.2 | 1600 | 5~2.7 |
CXA-0540 | 10.8~13.2 | 1600 | 6.5~2.5 |
CXA-0492 | 10.8~13.2 | 2050 | 6~2.5 |
BHSS-1- TB(LF)(SN) / JST | CXA-16012PJ102 | 10.8~13.2 | 1700 | 6~3 |
6~8 U Shape | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-0524 | 10.8~13.2 | 1200 (Double high-voltage) | 5~2.6 |
SM02B-BHSS-1- TB(LF)(SN) / JST | CXA-0510 | 10.8~13.2 | 1200 (Double high-voltage) | 6~3 |
| Connector Type | 2 | Current | 5~8 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-0356 | 4.75~5.25 | 1500 | 6~3 |
CXA-0502 | 9.6~14.4 | 1900 | 6~3 |
5~12 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-0393 | 10.8~13.2 | 1600 | 6~2 |
10~15 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-0217 | 9.6~14.4 | 1400 | 6~2 |
PWM | 5~6 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-0406 | 4.75~5.25 | 1050 | 6.4~3.2 |
CXA-0320 | 10.8~13.2 | 1200 | 5~2.2 |
SM03(7-D1)B-BHS-1- TB(LF)(SF) / JST | CXA-0462 | 10.8~13.2 | 1400 | 5~2.6 |
5~8 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-0326 | 9~19 | 1000 | 5.5~2.5 |
SM03(7-D1)B-BHS-1- TB(LF)(SF) / JST | CXA-0420 | 4.5~13.2 | 1100 | 5~2.5 |
CXA-0441 | 4.5~5.5 | 1250 | 5~2.6 |
CXA-0548 | 10.8~13.2 | 1400 | 6~2.9 |
CXA-0437 | 10.8~13.2 | 1250 | 5~2.6 |
5~10 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-0549 | 10.8~13.2 | 1250 | 6~2 |
CXA-0457 | 10.8~13.2 | 1600 | 6.5~3.7 |
SM03(7-D1)B-BHS-1- TB(LF)(SF) / JST | CXA-0463 | 10.8~13.2 | 1300 | 6~2.5 |
8~10 | SM03(4.0)B-BHS-1- TB(LF)(SN) / JST | CXA-0543 | 10.8~13.2 | 1200 | 5~2 |
SM03(7-D1)B-BHS-1- TB(LF)(SN) / JST | CXA-0513 | 9.6~14.4 | 1900 | 6~2.5 |
CXA-0496 | 10.8~13.2 | 1400 | 6~4.3 |
CXA-0474 | 11.4~12.6 | 1750 | 5~2.5 |
8~12 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-P1212E-WJL | 10.8~13.2 | 1500 | 6~2 |
CXA-0454 | 10.8~13.2 | 1500 | 6~3 |
CXA-26012PJ103 | 10.8~13.2 | 1700 | 6~3 |
SM03(7-D1)B-BHS-1- TB(LF)(SN) / JST | CXA-0368 | 10.8~13.2 | 1500 | 6~2 |
CXA-P1212D-WJL | 10.8~13.2 | 1500 | 6~2 |
CXA-0359 | 11.4~12.6 | 1600 | 5~2.2 |
CXA-26012PJ104 | 10.8~13.2 | 1700 | 6~3 |
8~15 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-26012PJ105 | 10.8~13.2 | 1700 | 6~3 |
10~15 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-P1612-VJL | 10.8~13.2 | 1500 | 8~4 |
CXA-0523 | 10.8~13.2 | 1600 | 7.5~3.9 |
15 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-0508 | 11.4~12.6 | 1500 | 6.5~3 |
SM02B-BHSS-1- TB(LF)(SN) / JST SM02(4.0)B-BHS-1TB(LF)(SN) / JST | CXA-0535 | 10.8~13.2 | 1700 | 6.5~3 |
| Connector Type | 4 | PWM | 10~12 | SM03(7-D1)B-BHS-1- TB(LF)(SN) / JST | CXA-0453 | 10.8~13.2 | 1500 | 6.5~3.7 |
15 | SM02B-BHSS-1- TB(LF)(SN) / JST SM02(4.0)B-BHS-1TB(LF)(SN) / JST | CXA-0535 | 10.8~13.2 | 1700 | 6.5~3 |
15~17 | SM02(8.0)B-BHS-1- TB(LF)(SN) / JST | CXA-46012PJ107 | 10.8~13.2 | 1700 | 6~3 |
SM02B-BHSS-1- TB(LF)(SN) / JST | CXA-0488 | 10.8~13.2 | 1800 | 6.9~3.8 |
CXA-46012PJ106 | 10.8~13.2 | 1700 | 6~3 |
SM03(7-D1)B-BHS-1- TB(LF)(SN) / JST | CXA-46012PJ108 | 10.8~13.2 | 1700 | 6~3 |
SM02B-BHSS-1- TB(LF)(SN) / JST SM02(4.0)B-BHS-1TB(LF)(SN) / JST | CXA-0494 | 10.8~13.2 | 1950 | 5~4.3 |
CXA-46012PJ109 | 10.8~13.2 | 1700 | 6~3 |
6 | 15 | SM03(6.0)B-BHS-1R-TB(LF)(SN) / JST SM03(4.0)B-BHS-1TB(LF)(SN) / JST | CXA-0503 | 11.4~12.6 | 1700 | 6.5~4.3 |
19~21 | SM02B-BHSS-1- TB(LF)(SN) / JST | CXA-0379 | 11.4~12.6 | 1700 | 6~3 |
