产品选型
东电化兰达 UNA系列单体式电源
东电化兰达 UNA系列单体式电源
2014/4/15 15:31:13
东电化兰达 UNA系列单体式电源
产品分类:
工业电源 UPS
品牌:
东电化兰达
UNA SERIES
Embedded power supply/DC-UPS 300W(350W PEAK)
UNA-SERIES
Product lineup
UNA350PN
Power supply unit,no backup type
UNA-HA01-PN
Harness set for UNA350PN
UNA350PB
Power supply unit,battery backup type
UNA-HA01-PB
Harness set for UNA350PB
UNA-BT242R3
Lead battery unit
UNA-HA01-BT
Battery cable
Features
  • Conforms to ATX12V Ver1.3 Spec.
  • Detechable type of harness applied to output.(makes cable connection flexible)
  • Compiles with Lead free manufacturing process
  • Uninterrupted switches to battery backup operation in blackout(UNA350PB only)
Specifications(catalog download)(technical data download)
Output ChannelV1V2V3V4V5(VSB)
Nominal output voltage 3.3V 5V 12V-12V 5V
Minimum load0A0.5A0A
Rating output current16A25A15A0.5A2A
Total output power150W
284W
300W
Peak Current28A30A19.5A0.8A2.5A
Peak output power
(Peak Max 5s interval 3minutes Ta=40�C)
195W
328W
350W
Input voltage range85~265VAC(47~63Hz)
PFHCEN61000-3-2 ClassA
Battery voltage(*1)DC20V~24V
Back up time(*1)1.5min at 250W Load(with UNA-BT242R3,Ta=25�C)
Capacity of battery unit (*1)24V 2.3Ah(5inch bay size)
Output signalPWR_OK FAN-ALM(2puls/r) AC-fall(*1)Balt Low (*1)
Input signalPS_ON ,Shut Down(*1)
Safety standardConform to UL60950-1,CSA60950-1,EN60950-1,EN50718,CCC
(*1)only for UNA350PB
*Needs output derating according to installation method or ambient temperalure condition.
Mother Board side
(UNA350PB+UNA-HA01-PB)
C N
NAME
Pin
No.
FANCTIONW I R ECONNECTOR
T Y P E
COLORTYPE
P11 3.3VORANGEUL1007 AWG18HOUSING
5557-20R(Molex) or equivalent
TERMINAL
5556PBT(Molex)or equivalent
2 3.3VORANGE
3COMBLACK
4 5VRED
5COMBLACK
6 5VRED
7COMBLACK
8PWR_OKGRAY
9 5VSBPURPLE
10 12VYELLOW
11 3.3V & senceORANGE & BROWN(BROWN AWG22)
12-12VBLUEUL1007 AWG18
13COMBLACK
14PS_ON#GREEN
15COMBLACK
16COMBLACK
17COMBLACK
18NC--
19 5VRED
20 5VRED
P21COMBLACKUL1007 AWG22HOUSING
51030-0630(Molex)
TERMINAL
50084-8014(Molex)or equivalent
2Shut Down(TTL)YELLOW
3AC Fail(TTL)BLUE
4BATT Low(TTL)WHITE
5NC--
6FAN ALMPURPLE
P3
P4
P6
P7
P8
1 12VYELLOWUL1007 AWG18HOUSING
1-480424-0(AMP)
TERMINAL
170120-4(AMP)or equivalent
2COMBLACK
3COMBLACK
4 5VRED
P51 5VREDUL1007 AWG20HOUSING
171822-4(AMP)
TERMINAL
170262-2(AMP)or equivalent
2COMBLACK
3COMBLACK
4 12VYELLOW
P91COMBLACKUL1007 AWG18HOUSING
5557-04R(Molex)or equivalent
TERMINAL
5556PBT(AMP)or equivalent
2COMBLACK
3 12VYELLOW
4 12VYELLOW
(UNA350PN+UNA-HA01-PN)
C N
NAME
Pin
No.
T Y P E
COLORTYPE
TERMINAL
2 3.3VORANGE
3COMBLACK
4 5VRED
5COMBLACK
6 5VRED
7COMBLACK
8PWR_OKGRAY
9 5VSBPURPLE
10 12VYELLOW
13COMBLACK
14PS_ON#GREEN
15COMBLACK
16COMBLACK
17COMBLACK
18NC--
19 5VRED
20 5VRED
P3
P4
P6
P7
P8
1-480424-0(AMP)
TERMINAL
2COMBLACK
3COMBLACK
4 5VRED
171822-4(AMP)
TERMINAL
2COMBLACK
3COMBLACK
4 12VYELLOW
5557-04R(Molex) or equivalent
TERMINAL
2COMBLACK
3 12VYELLOW
4 12VYELLOW
As for the mention contents of this page, understand beforehand because it sometimes changes.
美的楼宇科技荣获建筑绿色供热领域国家科技进步奖
吉方工控携手英特尔共谱智能制造“交响乐”,高性能工控机赋能行业创新
联想方案服务探索之路:以AI原生带来新质生产力
克洛托光电产业研发及产业化项目建设有新进展
鸿蒙赋能 智创未来!国内燃气行业首个燃鸿系列产品重磅发布
