Teledyne DALSA Piranha4 2k, 100/200 kHz相机
Based on Teledyne DALSA's unique line scan CMOS sensor architecture, the new Piranha4 dual line scan cameras deliver the highest line rates in the industry with outstanding signal-to-noise.
产品分类:机器视觉 CCD/CMOS照相机
品牌:产品介绍
Based on Teledyne DALSA's unique line scan CMOS sensor architecture, the new Piranha4 dual line scan cameras deliver the highest line rates in the industry with outstanding signal-to-noise. The P4-2k has 2k resolution with a 10.56 μm x 10.56 μm pixel size. The camera delivers a max line rate of 100 kHz inTDI mode, or up to 200 kHz in area mode. The camera delivers a throughput of 410 MPix/s using the Camera Link?, and advanced chipsets allow cable lengths of ~30 meters and beyond. The GenICam? compliant interface makes the camera easier to set up, control, and integrate.
The Piranha4 backs up its incredible speed with a wide range of advanced features. It offers shading correction and flat field correction, and its HDR mode captures high gain and low gain views simultaneously, allowing you to combine them in postprocessing. Programmability includes exposure control, independent gain settings, as well a multiple areas of interest (up to 4 simultaneous) which allow you to focus on specific areas of an image and ignore the rest, reducing processing bandwidth and even simplifying cabling.
特征亮点
●Line rates up to 100 kHz in TDI mode, 200 kHz in area mode
●Dual line CMOS sensor architecture for 2x responsivity
●2k resolution, 10.56 µm pixels
●100% fill factor
●Multiple areas of interest
●Dual exposures for HDR imaging
●Vertical and horizontal binning 1x, 2x
●Low pass shading and lens correction, flat field correction
●In-camera diagnostics and test patterns
●0-65°C operating temperature
●Camera Link interface supporting cables to 15 meters and beyond
●GenICam compliant
AI 检测如何更精准高效?Teledyne FLIR 机器视觉相机告诉你
用于 TX2 的 Quartet 嵌入式解决方案
神级Teledyne FLIR Blackfly® S USB3,为解决水果检测、机器人开发、城市监测而生
AWM Frictionless™ 使用 Teledyne FLIR 机器视觉摄像头可以完成自动结账
机器视觉创新产品——Emerald™67M图像传感器助力显示器和高端电子产品的检测应用
