浩亭 板对板和PCB接线端子
HARTING develops board-to-board connectors for economical assembly of electronic devices and equipment and offers the most comprehensive range of highly versatile connectors and PCB terminal blocks complemented by many styles of shell housings for a complete interconnection and interface system.
产品分类:品牌:
Regardless of your device configuration, HARTING always has an ideal board-to-board connector with maximum packing density and optimal performance with regard to signal transmission and integrity.
For many years, connectors to DIN 41 612 in the pitch of 2.54 mm have established themselves as a standard both for board-to-board and cable-to-board applications. HARTING offers a wide product range of DIN 41 612 connectors for data, signal and power lines, including corresponding accessories.
The HARTING 5 row 160 way VME 64x connector range har-bus® 64 is the extension of the DIN 41612 standard 3 row 96 way C type connectors. HARTING is the only manufacturer that offers the complete VME64x connector range including male connectors, straight and right-angled female connectors, shrouds, cable connectors and housings.
Mini Coax connectors in the pitch of 6.25 mm facilitate multi-channel, coaxial and high frequency data transmission for board-to-board and cable-to-board applications. Device integration is supported with straight and angled contact inserts with press-in technology and SMT/SMC. The housings support applications up to IP65.
har-bus® ® hard metric connectors in the pitch of 2.00 mm form the basis for the assembly of high-performance backplanes for control systems and for industrial computer systems with 19“ technology. The board-to-board connectors are available with press-in technology for backplanes and solder versions for sub-boards.
TCA connectors in the pitch of 0.75 mm represent the next generation of backplane connectors. Their new concept supports direct or indirect connection. A special connector covers particularly rugged connections on the basis of indirect connection. TCA connector versions are available for connecting data channels and the power supply to the modules.
The HARTING MCE Micro Card Edge connector in the pitch of 0.8 mm is designed for applications requiring board-to-board mezzanine or small pluggable daughter card connections. The key feature is the very flexible stacking height of parallel boards by utilizing a small board between the connectors.
HARTING board-t ®o-board connectors and PCB terminal blocks incorporate the latest design features and provide the assurance of high quality and reliability with economy. For "non-standard applications" we can manufacture designs to match your requirements. Please discuss your requirements with us.
更多信息请访问: www.harting.com.cn
浩亭再次荣膺“年度最佳公司”
浩亭全新Mini PushPull ix Industrial®坚固耐用,可承受恶劣环境
浩亭凭借Han-Modular® 多米诺模块荣赢得最佳工业奖
岁末回顾 | 2022年浩亭大事记
倒计时1天!这场线上视听盛宴不容错过
