宜鼎国际 Industrial micro SD Card
宜鼎国际 Industrial micro SD Card 产品的详细介绍。
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
S.M.A.R.T / iSMART disk health monitoring tool
Intelligent error recovery system
Excellent data transfer speed
Static and global wear-leveling algorithm
Enhanced power cycling
Overview
The Innodisk Industrial microSD card is a tiny, SLC-based storage solution designed for ruggedized embedded applications. This industrial-grade device delivers data transfer reliably and provides excellent long-lasting performance. It is also compatible with SD 1.1 and SD 2.0 standards and supports SDHC Class 10 and SPI modes. Innodisk’s Industrial microSD card card consumes little power and is available in capacities ranging from 1GB to 8GB.
Benefits
The Innodisk IIndustrial microSD Card provides manufacturers with confidence and ease of mind when it comes to performance management.
Detects and correct errors automatically during data transfer with built-in ECC function within the card
Supports standby and sleep mode, effectively reducing power consumption in advance for applications with a limited power source
Ensures an optimal working condition, including detecting and reporting various indicators, such as erase count, bad block count, ECC reliability, and lifespan, which are monitored through the S.M.A.R.T function
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
