集智达智能SBC-3961嵌入式主板
嵌入式主板SBC-3961
产品分类:嵌入式系统 物联网 应用层 嵌入式主板 嵌入式应用
品牌:集智达智能
主要特点
1.AMD low power LX800 500MHz Processor
2.Supports DDR memory
3.Supports 24-bit TFT LCD interfaceSupports 18-bit LVDS LCD display Supports Dual 100Base-T
Fast Ethernet Support Four USB2.0 ports
4.Support Six COM ports
产品规格:
Standard 3.5" Biscuit SBCFunctions
CPU: AMD Geode® LX800 processor, up to 500 MHz
System Memory: OnBoard 512M Double Data Rate (DDR) SDRAM
2nd Cache Memory: 128 KB on the processor
System Chipset: AMD Geode LX800
BIOS: AWARD 2Mbit Flash BIOS Watchdog timer: 255 levels timerinterval Expansion Interface
Battery: Lithium 3V/196 mAH
Power management: APM 1.2, ACPI supported
Enhanced IDE interface: One channels supports up to two EIDE devices. BIOSauto-detect, PIO Mode
3 or Mode 4, supportsUDMA 33/66 mode
Serial ports: Six serial ports, 6 ports for RS-232
Parallel port: One parallel port, supports SPP/EPP mode Keyboard/mouseconnector: Supports one
standard PC/AT keyboardand a PS/2 mouse
Audio: Support AC97 Audio stereo sound
USB: Four USB 2.0 compliant universal serial bus ports
Solid State Disk (SSD) :Supports one 50-pin socket for CFC type I (type IIoptional) 1.3.2 VGA/LVDS
Interface
Memory Size: Optimized Shared Memory Architecture, support 64MB framebuffer using system
memory
Resolution: CRT resolution: up to 1600 x 1200 x 16Bpp at 100 Hz andup to 1024 x 768 x 32bpp at 60
Hz for TFT LCD
LCD Interface: Supports up to 18 or 24-bit TFT LCD (TTL signal)
LVDS Interface: Supports one channel 18 LVDS
Dual SimultaneousDisplay: CRT + LCD, CRT + LVDS
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
