集智达智能SBC-3662嵌入式主板
嵌入式主板SBC-3662
产品分类:嵌入式系统 物联网 应用层 嵌入式主板 嵌入式应用
品牌:集智达智能
主要特点:
1. AMDlow power LX800 500MHz Processor
2.SupportsDDR memory
3.Supports24-bit TFT LCD interface
4.Supports24-bit LVDS LCD display
5.SupportsDual 100Base-T Fast Ethernet
6.SupportFour USB2.0 ports
7.SupportSix COM ports
8.WithPC/104 Plus expansion interface
产品规格:
CPU: AMD Geode® LX800 processor, up to 500 MHz
System Memory: OnBoard 256M Double Data Rate(DDR)
SDRAM
2nd Cache Memory: 128 KB on the processor
System Chipset: AMD Geode LX800
BIOS: AWARD 2Mbit Flash BIOS
Watchdog timer: 255 levels timer interval
Expansion Interface: PC/104 Plus
Battery: Lithium 3V/196 mAH
Power management: APM 1.2, ACPI supported
Enhanced IDE interface: One channels supports up to two EIDE
devices. BIOS auto-detect, PIO Mode 3 or Mode 4, supports
UDMA 33/66 mode
Serial ports: Six serial ports, 6 ports for RS-232
Parallel port: One parallel port, supports SPP/EPPmode
Keyboard/mouse connector: Supports one standard PC/AT
keyboard and a PS/2 mouse
Audio: Support AC97 Audio stereo sound
USB: Four USB 2.0 compliant universal serial bus ports
Solid State Disk (SSD) Supports one 50-pin socket for CFCtype I
(typeII optional)
1.3.2 VGA/LVDS Interface
Memory Size: Optimized Shared Memory Architecture,support
64MB frame buffer using system memory
Resolution: CRT resolution: up to 1600 x 1200 x 16 bpp at 100 Hz
and up to 1024 x 768 x 32 bpp at 60 Hz for TFT LCD
LCD Interface: Supports up to 18 or 24-bit TFT LCD(TTL signal)
LVDS Interface: Supports one channel 18 or 24-bit LVDSor two
channel 18 or 24-bit LVDS Interface
Dual Simultaneous Display: CRT + LCD, CRT + LVDS
Chipset supports: 2 x10/100Mbps - Realtek RTL8100CL
Interface: 2 x RJ-45 connectorStandard IEEE 802.3u (100
BASET)protocol compatible
1.3.4 Audio Function
Audio controller: RealtekACL655 chipset, supports AC97 3D
Audio stereo sound
Audio interface: Microphonein, Line in, Line out, Speaker out
1.3.5 OS support
This board supports Win XP, Win CE ,Win XPeand .
1.3.6 Mechanical and Environmental
Dimensions: 102mm×145mm 3.5”
Power Supply Type: AT/ATX
Power Requirement: +5 V± 5%, +12 V ± 5% (Optional), +5 V
standy for ATX mode or support single +5 Vpower only
Power Consumption:
(Geode LX800, 256 MB DDR333)
Max: +5 V @ 1.2 A, +12 V @ 0.23 A
Typical: +5 V @ 0.6 A, +12 V @ 0.03A
Operating temperature: 0 ~60°C (32 ~ 140°F)
Operating Humidity: 10%~ 90% relative humidity, noncondensing
Weight: 0.85 kg (reference weightof total package)
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
