关键字: | 平板电脑 |
产品分类: | 工控机 工控机整机 平板电脑(PPC) |
品牌: | 艾讯宏达 |
- 产品简介:
- 艾讯宏达推出基于ARM Cortex-A9平台(双核1.5GHz)的工业平板电脑PAD6315-ARM,支持Android 4.2 或以上系统,整机功耗仅15W。
特点:
1. 高效能低功耗工业平板电脑(最大功耗15W以下)
2. CPU:ARM Cortex-A9双核1.5GHz(VIA WM8880)
3. 支持4个RS232串口(可支持一个RS422/485)
4. 板载1GB DDR3内存
5. 板载2GB NAND Flash,最大支持32GB Micro SD扩展
6. 支持WIFI/3G/4G/GPS模块扩展
7. 支持Android 4.2或以上系统
8. 采用工业级五线电阻式触摸屏
9. 提供灵活的客制化系统服务
详细规格:
System SPEC | Processor | ARM Cortex-A9 Dual Core Processors |
RAM | Onboard DDR3 1066MHz Memory up to 1GB | |
Storage | Onboard 2GB NAND Flash | |
Micro_SD | Support up to 32GB Micro_SD Card | |
Watchdog | Watchdog timer function | |
Front Panel | Aluminum Panel,Oxidation sandblasting,Black or White (Option) | |
IP65 | YES | |
Power Supply | DC12V/5A Power Adapter | |
Size | W×D×H = 375×50×300mm | |
Weight | 3.5kg | |
Screen | LCD Size | 15 inch 4:3 |
Display Type | LED | |
Resolution | 1024×768 | |
Display Color | 16.7M | |
Viewing Angle | 85/85/85/85 | |
Brightness | 400cd/c㎡ | |
Contrast | 1500:1 | |
Touch Screen | Industrial Five-wire resistive touch screen | |
I/O | USB Ports | 2 ×USB2.0 |
LAN Ports | 1×RTL8152B | |
COM Ports | 4×RS232 (Or 1×RS485 Option) | |
PWR SW | 1 × Power switch | |
WIFI | Support 1*Mini-PCIe Wifi Device | |
Power Input | DC12V IN |
