集智达智能IPPC 2132P平板电脑
21.5" TFT 16:9全高清重工业平板电脑,支持Intel® Atom™ D2550,1.86GHz, 多点触控, 4GB DDR3, 4 x USB, 2 x COM與VGA, 已安装现场总线模块
产品分类:工控机
品牌:集智达智能
产品介绍:
The 21.5" fanless panel PC IPPC 2132Pincorporating an industrial motherboard is intended for versatile industrialapplications. The panel PC has a touch screen LED backlight LCD panel with 1920x 1080 (Full HD) resolution. The front panel which adopts flush design andcomplies with IP66 standard makes it the perfect fit in industrial applications.
The IPPC 2132P supports WWAN/WLAN expansionand others via dual Gigabit Ethernet connectors, two Mini-PCIe slots and oneSIM card holder. With support for wide power input of 12V~30V, IPPC 2132P cangain a strong foothold in industrial field and machine devices. In addition,IPPC 2132P can hook 2nd display via a VGA port for dual independent display.IPPC 2132P has two isolated RS232/422/485 ports, four isolated channels of DIand DO, and optional fieldbus ports.
主要特点:
Intel® Atom™ D2550, dual core, low power consumption CPU
Metal housing with robust aluminum front zero bezel for harshenvironment
10 points P-Cap multi-touch with zero bezel flush front design
Dual GbE/2nd display-VGA/Line-out
USB x4/2 x Mini-PCIe sockets/1 x CFast/2 x RS232/422/485
DDR3 4GB/2.5" HDD bracket
IP66 compliant front panel
Support fieldbus module, JMobile HMI, Citect SCADA and CODESYSSoftLogic (optional)
Mounting Support: panel/wall/stand/VESA 100mm x 100mm
Wide range power input 12V~ 30V DC
车规MOSFET技术确保功率开关管的可靠性和强电流处理能力
2023年制造业“开门红”,抢滩大湾区市场锁定DMP工博会
2023钢铁展洽会4月全新起航 将在日照触发更多商机
