CPU | Intel LGA1155 Socket support up to 77W processors with Intel Core i7/i5/i3/Pentium/ Celeron desktop Processors, CPU TDP no higher than 77W | Chipset | Intel H61 Express Chipset | Memory | Two 240-pin DIMM support DDR3-1333/1066 SDRAM, (Non-ECC up to 16GB) |
Graphic Controller | Integrated graphics support for processors with Intel Graphics Technology | Video Memory | Shared Memory | Video Interface | ● 2 x VGA (DB15) ● 1 x LVDS |
Ethernet | 2 x Gbps RJ45 with LED, Realtek RTL8111E GbE | Expansion Slot | ● 1 x PCI-E x16 slot ● 1 x Mini PCIe slot | Serial Port | ● 1 x RS232 (DB9) ● 1 x RS232/485 (Pin Header) ● 8 x RS232 (Pin Header) | USB | 8 x USB 2.0 ( 4 x Rear, 4 x Pin Header) | GPIO | 8-bit Digital I/O | Paralle Port | 1 x LPT DB25 | PS/2 | 1 x Keyboard or Mouse | Audio | Realtek ALC662 Audio Codec |
Hardware Montoring | Monitoring temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats. | WatchDog Timer | Software programmable 1~255 sec./mins. |
Power Input | ● 1 x 20-pin ATX Power Connector ● 1 x 4-pin ATX 12V Power Connector | Power Consumption | TBD |
OS Support | ● Windows XP ● Window 7 (32bit) ● Fedora 17 (32bit) |
Dimension | 170 mm x 170 mm | Weight | TBD | Operating Temp. | 0~50°C (32~140°F) | Storage Temp. | -20~80°C (-4~176°F) | Relative Humidity | 10%~90% (non-condensing) | Safety | CE, FCC compliant |
● 1 x AMB-IH61T3 | ● 1 x Driver CD | ● 1 x Quick Guide | ● 1 x IO Shield | ● 2 x SATA Cable | ● 1 x Cooler Module (ACC-IH61T3-H500) | ● 1 x COM2 Cable | ● 1 x COM3~6 Cable | ● 1 x COM7~10 Cable |
AMB-IH61T3 | Intel® H61 Mini-ITX Motherboard, 2 x VGA, 2 x GbE, 10 x COM, 8 x USB, 1 x PCI-E x16, 1 x Mini PCIe, With Cooler Module |
ACC-IH61T3-H500 | W90 x L90 x H50 mm, 3600RPM, 38dBA | Specifications are subject to change without notice. |
