产品选型
元大科技 PCM-3202P 2-port Master Card
PCM-3202P is a PCI/104+ interface card which supports two AMONet RS-485 master rings.
产品分类:
工控机 专用板卡 运动控制卡
品牌:
元大科技
特点
Max. 20 Mbps transfer rate
2 independent AMONet RS-485 Master Rings
Max. 64 AMONet RS-485 slave modules supported per ring
Supports a communication distance of up to 100m@10Mbps
Programmable digital input for event notification events
概述
PCM-3202P is a PCI/104+ interface card which supports two AMONet RS-485 master rings, and transfers data between host and slaves directly without the need for further intervention. Each ring can control up to 2,048 I/O points, 256 axes, or a combination of I/O points and axes for motion control. The ring can support a transfer rate of up to 20 Mbps transfer rate and a maximum communication distance of up to 100 meters.
The communication between master and slave is based on a customized RS-485 solution that saves wires, covers a long distance, supports high-speed communication and has time-deterministic features. The communication interface between master and host PC is accomplished by memory mapping. Various functions can be chosen on the slave modules, and standard industrial DIN-rail mounting design makes it easy to distribute them in the field. The master collects information from the slave modules and publishes the information to the host PC.
工业级NAND的发展历程
2021 NAND Flash 原厂蓄力瞄准SSD市场
DDR5标准正式发布啦!!!
CNC解决方案
研华高端显示屏套件 满足海事应用严苛环境需求
