宜鼎国际 宽温系列 DDR3 LONG DIMM内存条
宽温系列:DDR3 LONG DIMM
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
JEDEC standard 1.35V(1.28V~1.45V) & 1.5V(1.425V~1.575V) Power Supply
JEDEC Standard 240-pin Dual In-Line Memory Module
8 bit pre-fetch
On Die Termination with ODT pin
Bi-directional Differential Data Strobe
SDRAM operating temperature range -40°C ≤ TA ≤ +85°C
Gold Finger 30μ"
RoHS Compliant
Overview
Designed for industrial systems, Innodisk’s Wide Temperature DRAM modules are best suited for applications that must work in extreme temperatures. These modules use industrial-grade SDRAM components with 30u” gold finger to ensure that the memory maintains its high-quality signal, even at temperatures as low as -40ºC or as high as 85ºC.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
