产品选型
欣扬电脑 Mini-ITX AMB-IH81T1工控机主板
英特尔H81与酷睿TM i7处理器/酷睿i5/ i3的Mini-ITX主板,DDR3-1333/1600 SDRAM,2个VGA,2个千兆网卡,12×COM,10个USB接口,1个PCIE x16系统,1个迷你的PCIe
产品分类:
工控机 嵌入式系统 物联网 应用层 嵌入式主板 工控机配件 嵌入式应用
品牌:
欣扬电脑
1.支持Intel第四代奔腾/赛扬/睿i3 / i5/ i7处理器
2.2×DDR3L-1333/1600MHz的,UDIMM,最高支持16GB
3.1个PCIE x16系统
4,1个迷你的PCIe,1个SIM卡插槽
5.2个千兆以太网,12×COM
6.2个USB 3.0端口,8个USB 2.0
7.2个SATA3.0,1个SATA2.0
System
CPU Support Intel LGA1150 socket
● Intel Pentium/ Celeron
● Intel 4th Generation Core i3/ i5/ i7
Chipset Intel® H81
Memory 2 x DDR3L-1333/1600MHz, UDIMM, up to 16GB
BIOS AMI UEFI BIOS
Video
Graphic Controller
Intel® HD Graphics
Video Memory
Shared Memory
Video Interface
2 x VGA
Storage
SATA
1 x SATA 2.0 Port + 2 x SATA 3.0 Ports
I/O
Ethernet Slot ● 1 x PCIe x16 slot
● 1 x mini PCIe (PCIe + USB signal)
Ethernet 2 x GbE LAN
Ethernet Chip
2 x Realtek PCI-E NIC RTL8111F
Serial Port ● COM1: RS232
● COM2: RS232/RS485
● COM3~10: RS232
● COM11~12: RS232
USB
● 6 x Header(USB2.0)
● 2 x Rear I/O(USB2.0)
● 2 x Rear I/O(USB3.0/USB2.0)
GPIO
8-bit Digital I/O
Audio
Realtek ALC662 5.1 Channel HDA Code
1 x MIC-in, 1 x Line out
Parallel Port
1 x Parallel Port
SIM
1 x SIM Card Slot
Keyboard
1 x PS/2 Header for Key Board/Mouse
Hardware Feature
WatchDog Timer
Software programmable 1~255 sec./mins.
Power Requirement
Power Input
1 x ATX 20-Pin + 12V 4-Pin power connector
Power Output
System Fan & CPU Fan connector
Software
OS Support
Window 7 (32bit/64bit), Windows 8.1( 32bit/64 bit)
Mechanical & Environment
Dimension
170 mm x 170 mm
Weight
TBD
Operating Temp.
0~60°C (32~140°F)
Storage Temp.
-20~70°C (-4~176°F)
Relative Humidity
5%~90% (non-condensing)
Safety
RoHS
Packing List
● 1 x AMB-IH81T1
● 1 x Quick User Guide
● 1 x Driver CD
● 1 x SATA Cable
● 1 x I/O Shielding
Ordering Information
AMB-IH81T1 Intel® H81 Chipset with Intel Pentium/ Celeron/ 4th Generation Core i3/5/7,
2 x GbE, 2 x COM, 8 x USB2.0, 2 x USB3.0, 1 x PCIe x16, 1 x Mini PCIe,
Optional Cable
● USB port cable (2.54mm)
● USB port cable (2.0mm)
● COM port cable
● Serial ATA data cable
Specifications are subject to change without notice.
欣扬電脑2017-2018 网通产品回顾与展望
欣扬电脑新推出全新的AIV-APL1V1FL无风扇车载计算机
来自欣扬电脑的感谢! 谢谢您参与欣扬的APTA展
欣扬电脑即将参加美国亚特兰大2017APTA EXPO展
欣扬电脑提供业界最佳应用的Mini-iTX嵌入式主机板解决方案
