宜鼎国际 强固型客制系列DDR3 SODIMM内存条
强固型客制系列DDR3 SODIMM
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
JEDEC standard 1.35V(1.28V~1.45V) & 1.5V(1.425V~1.575V) Power Supply
JEDEC Standard 244-pin Dual In-Line Memory Module
8 bit pre-fetch
On Die Termination with ODT pin
Bi-directional Differential Data Strobe
Average Refresh Period 7.8us at lower then TCASE 85°C, 3.9us at 85°C < TCASE ≤ 95°C
Gold Finger 30μ"
Support registered function
Low-Profile
RoHS Compliant
Overview
VLP Mini DIMM modules are designed with 17.9mm high dimensions
specifically for networking applications. They are compliant with JEDEC standards and are designed to improve thermal resistance. With the ECC function, the VLP Mini DIMM also ensures that data is corrected when corrupted data bits are found during data retrieval.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
