产品选型
欣扬电脑 1.7“/ 8”/10.1“/12.1”/15“工业平板电脑
英特尔 Atom E3845/ N2930,8’’TFT LCD,2GB DDR3,触摸屏,2个USB2.0 基于N2930英特尔的Atom E3845/主流性能的平板电脑配有残疾人专用的存储空间和IP65防水前面板。
产品分类:
工控机 工控机整机 平板电脑(PPC)
品牌:
欣扬电脑
1.7“/ 8”/10.1“/12.1”/15“工业紧凑型平板电脑
2.扁平的前面板触摸屏
3.无风扇设计
4.英特尔 Bay Trail SoC N2930(1.83GHz的)CPU内置/ E3845(1.91GHz)供选择
5.板载2GB DDR3L-1600MHz的/ 4GB(可选)
6.9〜36VDC宽范围电源输入
7. IP65标准
8.可选投射式电容触摸屏支持7H防划伤表面
General PC Feature
CPU Onboard Intel Bay Trail N2930(1.83GHz) Processor / E3845(1.91GHz ) for option
System Chipset Intel Bay Trail SoC
System Memory Onboard 2GB DDR3L-1600MHz / 4GB(option)
Display
Display Type
8"
Max. Resolution
800 x 600
Max. Color 262 K
Luminance (cd/m²) 350
Contrast Ratio 500 : 1
View angle(H°/V°) H:140° / V:125°
Backlight Lifetime 40,000(hrs)
Touch screen - Resistive Touch Window Type
Type
Resistive Touch Windows
Interface
USB
Light Transmission(%)
Resistive Touch Windows: 80%
Touch screen - Projected Capacitive Type
Type
Projected Capacitive Touch(For P Model)
Interface
USB
Projected Capacitive Touch: 90%
Storage
HDD 1 x SATA MO-297 SSD bay (Easy Accessible)
Movable device 1 x SD card slot, up to 32GB
I/O Port
USB
1 x USB 2.0 type A + 1 x USB 3.0 type A
Serial/Parallel
1 x RS-232 DB-9(COM2) + 1 x DB-9 RS-232/422/485 (Default RS-232)(COM1)
Audio
1 x Audio Line Out / 1 x HDMI Port (reserved, no printing)
LAN
2 x GbE LAN RJ-45
Power
1 x 3-pin Terminal Block DC Power input
1 x 2-pin connector for power on/off button
Expansion
Onboard expansion bus
1 x Internal mini PCIe slot (full size)
Power Requirement
Power Input
9~36V
Power Consumption Max: 10.8W Max:13.9W(P)
Software
OS Support
Windows Embedded Compact 7, Windows Embedded Standard 7,
Windows Embedded 8 Standard, Windows Embedded 8.1 Industry
Mechanical
Color
RAL 9007
IP Rating
Aluminum Die-casting Front Bezel and Chassis
Mounting
Panel Mounting, VESA 75 x 75
Dimension (mm)
231 x 176 x 50
Net Weight (Kgs)
1.9 kg
Environmental
Operating temperature(°C) 0~50°C
Storage temperature(°C) -20~60°C
Storage humidity
10 to 90% @ 40°C, non- condensing
Certification CE, FCC Class A, CB, UL
Ordering Information
AR-PA807(P)FL-D2550
8” WVGA Fanless HMI barebone with Intel N2930 / E3845 CPU, 2GB DDR3
RAM, Resistive touch screen, 9~36V DC input with adapter / Projected
Capacitive touch screen
, Aluminum chassis
Specifications are subject to change without notice.
欣扬電脑2017-2018 网通产品回顾与展望
欣扬电脑新推出全新的AIV-APL1V1FL无风扇车载计算机
来自欣扬电脑的感谢! 谢谢您参与欣扬的APTA展
欣扬电脑即将参加美国亚特兰大2017APTA EXPO展
欣扬电脑提供业界最佳应用的Mini-iTX嵌入式主机板解决方案
