宜鼎国际 SATA Slim 3MG-P内存卡
SATA Slim 3MG-P
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
SATA III soultion for industrial field
iSMART disk health monitoring
Intelligent error recovery system
Excellent data transfer speed
Zero mechanical interference
Compliant with JEDEC MO-297 standard
Overview
InnoDisk SATA Slim 3MG-P is SATA III 6Gb/s Flash based disk, which designed with standard SATA interface (7+15 SATA connector), and compliant with JEDEC MO-297 standard. With its smaller dimension, SATA Slim 3MG-P is an alternative solution of 2.5” SSD for those embedded system that may have mechanical and space concerns. InnoDisk SATA Slim 3MG-P operates under SATA III (6.0Gb/s) interface with excellent performance and reliability making it the ideal solution for a variety of applications, including embedded system, and industrial field.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
