产品选型
当前页面: 首页 >产品选型 >宜鼎国际 SATADOM™-SL 3ME3 V2内存卡
供稿:宜鼎国际股份有限公司 2016/3/17 16:55:46
0 人气:89
    关键字: 宜鼎国际 SATADOM™-SL 3ME3 V2 内存卡
    产品分类: 工控机 工控机配件 存储产品
    品牌: 宜鼎国际
    SATADOM™-SL 3ME3 V2
    Features
    Built-in Pin 8 power supply
    Best boot drive solution for server and embedded system
    SATA 6Gb/s interface
    High IOPS to reduce boot up timing
    DRAM-less, 100% data integrity
    Innovative Firmware Algorithm
    Anti-vibration mechanical design
    Built in iData Guard
    Overview
    Innodisk Serial ATA Disk on Module (SATADOM™) supports SATA III standard (6.0Gb/s) interface with excellent performance, and SATADOM-SL 3ME V2 is designed as the smallest form factor size that could enhance compatibility with various design applications.
    The innovative Pin8 uses the SATA connector itself as a power supply to drive the device without external cables. It could be connected directly to the SATA on-board socket on customers’ system without additional power cable. Besides, the booting time for operation and the power consumption is less than hard disk drive (HDD), and can work under harsh environment compile with ATA protocol, no additional drives are required, and the SSD can be configured as a boot device or data storage device.
    Specifications
    更多内容请访问 宜鼎国际股份有限公司(http://c.gongkong.com/?cid=15112)
    1. 我要试用产品
    2. 我要产品资料
    3. 我要技术支持
    4. 我要咨询采购
    性能:
    给性能打分
    质量:
    给质量打分
    易用:
    给易用打分
    服务:
    给服务打分
