宜鼎国际 SATADOM™-SV 3ME2内存卡
SATADOM™-SV 3ME2
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
Best boot drive solution for server and embedded system
SATA 6Gb/s interface
High IOPS to reduce boot up timing
Built-in Pin 7/ Pin 8 power supply
DRAM-less, 100% data integrity
Innovative Firmware Algorithm
Anti-vibration mechanical design
Built in iData Guard
Overview
Innodisk Serial ATA Disk on Module (SATADOM™) supports SATA III standard (6.0Gb/s) interface with excellent performance, and SATADOM™-SV 3ME V2 is designed as the smallest form factor size that could enhance compatibility with various design applications.
Particularly the 7th pin of SATA 7 pin connector and 8th pin on SATA connector can optionally be the built-in power VCC pin. In other words, it could be connected directly to the SATA on-board socket on customers’ system without additional power cable. Besides, the booting time for operation and the power consumption is less than hard disk drive (HDD).
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
