宜鼎国际 SATADOM™ D150SV-L存储器
SATADOM™ D150SV-L
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
Built-in Power Pin 7 VCC
S.M.A.R.T / iSMART disk health monitoring tool
Intelligent error recovery system
Excellent data transfer speed
Zero mechanical interference
Anti-vibration mechanical design
Overview
Qualified by Intel, InnoDisk’s SATADOM™ D150SV-L is the world’s smallest SATA SSD, featuring built-in Pin 7 VCC that enhances the functionality of various embedded applications. With its cable-less and rugged design, the D150SV-L provides high reliability and is easily integrated with other systems. The SATADOM™ D150SV-L is also lightweight, comes with a single channel, and is available in capacities from 1GB up to 16GB.
Benefits
The Innodisk SATADOM D150SV-L allows manufacturers to save both time and money.
Eliminates the need for an external power cable or SATA cable, saving system space and reducing wiring or mechanical interference
Meets SATA standards and is compatible with most operating systems, giving greater flexibility in system design
Designed with no moving parts to deliver faster loading speeds and better resistance to dust while producing less heat and noise; provides a rugged and reliable storage solution replacement for HDDs
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
