宜鼎国际 SATADOM™ D150QV存储产品
SATADOM™ D150QV
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
Built-in Power Pin 7 VCC
S.M.A.R.T / iSMART disk health monitoring tool
Intelligent error recovery system
Excellent data transfer speed
Write protection security
Zero mechanical interference
Anti-vibration mechanical design
Built-in thermal sensor
Overview
Qualified by Intel, InnoDisk’s SATADOM™ D150QV is the world’s smallest SATA SSD, featuring built-in Pin 7 VCC that enhances the functionality of various embedded applications. With its cable-less and rugged design, the D150QV provides high reliability, reduces mechanical interference, and is easily integrated with 1U systems. The SATADOM™ D150QV is also lightweight, comes with multiple channels, and is available in capacities from 2GB up to 64GB.
Benefits
The Innodisk SATADOM D150QV allows manufacturers to save both time and money.
Connects directly to the SATA on-board socket, eliminating the need for an external power cable or SATA cable, which saves system space and reduces wiring or mechanical interference
Improves data transfer reliability while the device is operating through a specially designed connector that features a latch
Enhances performance with an anti-vibration mechanism that utilizes a locked connector design
Reduces operation system boot time
Consumes less power than an HDD
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
