宜鼎国际 SATADOM™-ML 3SE-P存储产品
SATADOM™-ML 3SE-P
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
SATA 6Gb/s interface
SMART disk health monitoring
Intelligent error recovery system
Excellent data transfer speed
Dram buffer
Write protection security
Zero mechanical interference
Anti-vibration mechanical design
Overview
Innodisk SATADOM™-ML 3SE-P is designed as the standard SATA 7 pin connector with SATA interface, and supports SATA III standard (6.0Gb/s) with excellent performance. Regarding of mechanical interference, Innodisk SATADOM™-ML 3SE-P absolutely replaces the traditional hard disk and makes personal computer, in any field, smaller and easier.
Innodisk SATADOM™-ML 3SE-P effectively reduces the booting time of operation system and the power consumption is less than hard disk drive (HDD), and complies with ATA protocol, no additional drives are required, and can be configured as a boot device or data storage device.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
