宜鼎国际 FiD 1.8"SATA D150 SSD电子盘
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
1.8" housing
7+15 pin SATA
Low power consumption
Overview
The FiD 1.8"SATA D150 is an entry-level SLC SSD that supports most standard SATA port platforms. This economic SSD can save up to half the space inside a motherboard. The FiD 1.8" SATA D150 operates under SATA II (3.0Gb/s) protocol, delivering good performance and sustained read and write speeds of up to 130MB and 120MB per second respectively.
Benefits
The Innodisk FiD 1.8"SATA D150 SSD provides manufacturers with an effective replacement for hard disk drives (HDDs).
Good performance, small seek time, and no latency time
Reduces boot time of the operation system
Consumes less power than an HDD
Able to work in lower or higher temperatures than an HDD
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
