宜鼎国际 InnoRobust II 1.8” SATA SLC电子盘
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
Compliant with MIL-STD-810-F/G
Data security
Excellent data transfer speed
TRIM command set supported
Thermal sensor supported
Conformal coating (optional)
Overview
The InnoRobust II 1.8” SATA SSD is a high-capacity flash memory SSD designed for aerospace and defense applications. It comes with several data security functions, including SEraser, QEraser, Destroy, and Write Protect. The InnoRobust II 1.8” SATA SSD Series complies with the SATA II (3.0Gb/s) standard and ATA protocol, and delivers excellent performance, with sustained read and write speeds reaching 170MB/second and up to 140MB/second respectively.
Benefits
The Innodisk InnoRobust II 1.8” SATA SSD Series guarantees maximum protection in harsh environments and continuously stores data safely and securely.
Erases 128GB of data in seven seconds(SLC type)
Resists shock and vibration
Stays within temperature limits
Flushes all buffer data to the flash chip before total power loss
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
