TOPSSD T2000 series Industrial Grade SD card features high performance, low power consumption, high reliability and superb transfer rates. The card is suitable for removable storage applications that require security, convenience, performance and capacity. The industrial-grade extended temperature range of -20℃ to +70℃ is suitable for demanding industrial environments that require high reliability. TOPSSD Industrial Grade SD card supports a range of technology, including error correcting code (ECC), which ensures the integrity of data transfers by automatically detecting and correcting errors, and wear leveling technology, which ensures data is written evenly across all sectors, extending the life of the memory card.
天硕T2000系列工业级SD卡具有高性能、低功耗、高可靠性和卓越的传输速率。该卡适用于可移动存储应用程序,快捷方便,性能稳定,容量大。工业级扩展温度范围为-20~+70摄氏度,适用于要求高可靠性、耐用性要求的工业环境。topssd工业级SD卡支持高级容错技术(ECC),保证数据传输的完整性并自动检测和纠正错误;平均损耗算法,确保数据被均匀地写入各个存储区域,延长记忆卡的寿命。
基本描述 | |
型 号 | T2000SD08GB |
容 量 | 8GB |
闪存类型 | SLC NAND Flash |
读写速度 | Read: 25MB/s, Write: 25MB/s |
接 口 | SD 3.0 Compliance |
传输模式 | SD 1.1/2.0/3.0 |
可靠性 | |
纠错加密 | Flexible ECC engine, AES encryption engine 128 and 256-Bit, ECB, CBC, and XTS modes |
损耗控制 | Static and Dynamic wear-leveling |
MTBF | >3 million hours |
插拔寿命 | Repeated Plug/Unplug >3,000 cycles |
工作环境 | |
工作温度 | -20℃~ +70℃ |
存储温度 | -55℃~ +125℃ |
湿 度 | 10-95% Relative Humidity (Non-dewfall) |
抗 冲 击 | 1500G@0.5ms |
抗 振 动 | Sine (Non-op) : 20Grms,7~2000Hz / Random Vibration(op) : 6Grms, 10~500Hz |
电源需求 | |
输入电压 | DC 2.7~3.6V |
电源管理 | Management of sudden power-fails |
功 耗 | <0.7W in operation |
规格与保修 | |
外形尺寸 | 24mm x 32mm x 2.1mm |
重 量 | <2g |
保修期限 | 5 years |
