TOPSSD T5040 Disk-On-Module fits into any platform with an 40PIN IDE(PATA) interface and provides a simple, fast path upgrade. Designed for industrial embedded applications that require a speedy booting process, the T5040 Disk-On-Module upgrades the working environment efficiently and enhances data transfer rates with read and write performances of up to 50MB/s and 30MB/s respectively. In addition , it's shock proof and low power consumption SSD characteristics makes it the ideal choice as a storage solution.
天硕 T5040工业DOM电子硬盘适用于任何40pin IDE(PATA)接口平台,并提供了一种简单、快速的升级方式。天硕 T5040工业DOM电子硬盘专为需要快速启动的工业嵌入式应用设计,读取速度可达读50Mb/s和写30MB/s,有效地改善了工作环境和提高了数据传输率。此外,它的耐冲击、低功耗的SSD的特性使得选择它成为了一个理想的存储解决方案。
基本描述 | |
型 号 | T5040DOM08GB |
容 量 | 8GB |
闪存类型 | SLC NAND Flash |
读写速度 | Read: 50MB/s, Write: 30MB/s |
接 口 | 40PIN IDE(PATA) Interface |
传输模式 | PIO Mode:0-6, Multi word DMA Mode: 0-4, Ultra DMA Mode: 0-4 |
可靠性 | |
校验修正 | 4 symbols in a 512 Bytes sector with additional CRC |
损耗控制 | Static and Dynamic wear-leveling |
MTBF | >3 million hours |
插拔寿命 | Testing Condition: 3sec/cycle – Repeated Plug/Unplug 10,000 cycles |
工作环境 | |
工作温度 | -20℃~ +70℃ |
存储温度 | -55℃~ +125℃ |
湿 度 | 10-95% Relative Humidity (Non-dewfall) |
抗 冲 击 | 1500G@0.5ms |
抗 振 动 | Sine (Non-op) : 20Grms,7~2000Hz / Random Vibration(op) : 6Grms, 10~500Hz |
电源需求 | |
输入电压 | DC +5.0V ± 10% |
电源模式 | Auto Stand-by and Sleep Mode |
功 耗 | <95mA in operation |
规格与保修 | |
外形尺寸 | 59.1mm x 27.2mm x 7.4mm |
重 量 | <12g |
保修期限 | 5 years |
