西克 WL170-P122光电开关
2020/5/16 14:47:31
WL170-P122光电开关施克SICK
产品分类:离散传感器 物联网 光电开关 感知层 位置检测
品牌:西克
FEATURES
Sensor/detection principle Photoelectric retro-reflective sensor Dimensions (W x H x D) 12 mm x 37 mm Housing design (light emission) Rectangular Type of light Visible red light Light source LED MECHANICS/ELECTRONICS
Supply voltage 10 V DC ... 30 V DC Ripple ± 10 % Power consumption ≤ 30 mA 1) Output type PNP Switching mode Light/dark switching Switching mode selector Selectable via L/D control cable Response time ≤ 0.7 ms 2) Attenuation along light beam ≥ 20 % Connection type Cable, 2 m 3) Cable material PVC Conductor cross-section 0.18 mm² Housing material Stainless steel/ABS
Stainless steelOptics material PC Enclosure rating IP 67 Ambient operating temperature –25 °C ... +55 °C Ambient storage temperature –40 °C ... +70 °C UL File No. NRNT2.E128350 & NRNT8.E128350 1) Without load.
2) Signal transit time with resistive load.
3) Do not bend below 0 °C.
技术图纸
Dimensional drawing
Adjustments possible
Connection diagram
Characteristic curve
Sensing range diagram
邦纳BANNER OTBVN6 W/Y光电触摸按钮
LANBAO兰宝 电感式接近开关 LE08SN25DNO
M8圆柱型接近开关凯库恩KEKUHN
邦纳 LS2TP30-1050Q88安全光幕
邦纳 OTBVN6 W,Y光电按钮
