西克 WT9-2N160P05光电开关
2020/5/16 17:18:52
WT9-2N160P05光电开关施克SICK
产品分类:离散传感器 物联网 光电开关 感知层 位置检测
品牌:西克
FEATURES
Sensor/detection principle Photoelectric proximity sensor, Background suppression Dimensions (W x H x D) 12 mm x 40 mm x 22 mm Housing design (light emission) Rectangular Sensing range max. 50 mm ... 1,500 mm 1) Sensing range 50 mm ... 1,500 mm 1) Type of light Infrared light Light source LED Adjustment Potentiometer 1) Object with 90 % reflectance (referred to standard white, DIN 5033)
MECHANICS/ELECTRONICS
Supply voltage 10 V DC ... 30 V DC Ripple ≤ 5 Vpp Power consumption ≤ 30 mA 1) Output type NPN Switching mode Light/dark switching Response time ≤ 1,000 µs 2) Connection type Cable, 2 m 3) Conductor cross-section 0.14 mm² Housing material ABS
plasticOptics material PMMA Enclosure rating IP 69K Ambient operating temperature –40 °C ... +60 °C Ambient storage temperature –40 °C ... +75 °C UL File No. NRKH.E181493 & NRKH7.E181493 1) Without load.
2) Signal transit time with resistive load.
3) Do not bend below 0 °C.
技术图纸
Dimensional drawing
Adjustments possible
Connection diagram
Characteristic curve
邦纳BANNER OTBVN6 W/Y光电触摸按钮
LANBAO兰宝 电感式接近开关 LE08SN25DNO
M8圆柱型接近开关凯库恩KEKUHN
邦纳 LS2TP30-1050Q88安全光幕
邦纳 OTBVN6 W,Y光电按钮
