主要特性 * 超小型,内置放大器,NPN集电极开路输出 * 多种型号(K,T,L,Y,V型)适用于多种不同应用场合 * 通过控制线可选择Light ON/Dark ON模式 * 高速响应频率: 2kHz * 宽电源电压范围: 5-24VDC (易于连接不同的IC,继电器,可编程控制器) * 发射端/接收端窗口防尘保护设计 * 红色指示灯可指示动作状态 * 通过连接头接插方式连接 应用场合 * 适用于小型高精密机械:LCD半导体设备,图像检测系统和运送装置执行机构 * 适用于设定调色板位置,计算数量和检测旋转体的起始位置
型号说明
规格表
Model | NPN open collector output | BS5-K2M | BS5-T2M | BS5-L2M | BS5-Y2M | BS5-V2M | PNP open collector output | BS5-K2M-P | BS5-T2M-P | BS5-L2M-P | BS5-Y2M-P | BS5-V2M-P | Sensing distance | 5mm fixed | Sensing type | Through-beam(Not modulated) | Sensing target | ø0.8×2mm Opaque materials | Hysteresis | 0.05mm | Response time | Light ON : Max. 20㎲, Dark ON : Max. 100㎲ | Response frequency | 2kHz(refer to the measuring range of frequency response) | Power supply | 5-24VDC ±10%(Ripple P-P : Max. 10%) | Current consumption | Max. 30mA(at 26.4VDC ) | Light source | Infrared LED(950nm) | Operation mode | Light ON / Dark ON selectable by control wire | Control output | NPN or PNP open collector output Load voltage : Max. 30VDC Load current : Max. 100mA Residual voltage : Max. 1.2V | Protection circuit | Reverse power polarity protection, Overcurrent protection | Indicator | Operation Indicator: red LED | Connection | Connector type | Noise resistance | ±240V the square wave noise(pulse width:1㎲) by the noise simulator | Insulation resistance | Min. 20MΩ(at 250VDC megger) | Dielectric strength | 1,000VAC 50/60Hz for 1 minute | Light source | Infrared LED(950nm) | Vibration | 1.5mm or 300m/s2 amplitude at frequency of 10 to 55Hz in each of X, Y, Z directions for 2 hours | Shock | 500m/s2(approx. 50G) in each of X, Y, Z directions for 3 times | Environ- ment | Ambient illumination | Fluorescent lamp : Max. 1000㏓ (Receiver illumination) | Ambient temperature | -20 to 55℃, storage : -25 to 85℃ | Ambient humidity | 35 to 85%RH, storage : 35 to 85%RH | Protection | IP50(IEC standard) | Material | PBT | Approval | CE | Unit weight | Approx. 30g | ※ The temperature or humidity mentioned in Environment indicates a non freezing or condensation environment. 注意事项 1.浪涌 BS5系列未设置抗浪涌回路 使用时请注意遵守EN标准 2.外部光源 该产品未设置防止外部光源干扰回路,请将接收器远离外部光源干扰 3.布接方式 和动力线、高压线等分开布线,以避免由此造成的误动作或产品损坏 4.干扰发生源注意事项 若微型光电传感器周围有机器产生干扰(开关稳压器,电机等),请将机器的屏蔽线F.G接地 5.焊接(直接焊在端子上) 直接焊接在端子上时不要超过3秒(最大温度260℃).确认焊接时离端子根部1.5mm以上. 6.安装 使用M3螺钉拧紧(最大力矩0.49N·m(5.0kgf·cm).拧螺钉时,请使用垫片(Φ6).请确认光电传感器收发光部分不与任何其他物体接触.若该部分划损时,产品会发生误动作. 7.维护 若传感器安装在有许多灰尘或潮湿的环境中,请注意清洁接收器,用干布擦干发射器和接收器,沾染灰尘会发生误动作 8.其他 安装传感器时远离: 易腐蚀性气体,油,灰尘,水蒸汽,强酸强碱,强光 ※请注意遵守上述说明以避免发生误动作或损坏产品
注意安全
