盈美智phrontier PHOX-Base光纤适配器
24 bit, Base CL,66MHz (85MHz 可选),光纤延长
产品分类:机器视觉 其它
品牌:盈美智
Camera Link 接口 | ||||
最大像素时钟 | 66 MHz | |||
最大数据位宽/像素 | 24 bits | |||
兼容性 | Base Camera Link | |||
连接器类型 | MDR 26 pin | |||
Opto-isolated GPIO接口 | ||||
I/O通道数 | 2输入和2输出( opto-isolated) | |||
工作电压 | 0~3.3V (0~5.0V 可选) | |||
最大数据速率 | 1 Mbps | |||
连接器类型 | DB9 male | |||
RS232接口 | ||||
数据通道数 | 4 – RxD TxD RTS CTS | |||
工作电压 | Input: +/- 25V, Output: +/- 6V | |||
最大数据速率 | 250 Kbps | |||
连接器类型 | DB9 female | |||
光学接口 | ||||
工作波长
| PHOX-BM-00250 | 850nm | ||
PHOX-BL-10 | 1310nm | |||
PHOX-BL-20 | 1310nm | |||
PHOX-BL-40 | 1550nm | |||
PHOX-BL-50 | 1550nm | |||
发送器最小输出功率 | PHOX-BM-00250 | -9.5 to -4 dBm | ||
PHOX-BL-10 | -10 to –3 dBm | |||
PHOX-BL-20 | -5 to 0 dBm | |||
PHOX-BL-40 | -5 to 0 dBm | |||
PHOX-BL-50 | -2 to +3 dBm | |||
接受器最小输出功率 | PHOX-BM-00250 | -17 dBm
PHOX-BL-10 | -18 dBm | |||
PHOX-BL-20 | -18 dBm | |||
PHOX-BL-40 | -18 dBm | |||
PHOX-BL-50 | -18 dBm | |||
连接器类型 | LC duplex | |||
光纤类型 | PHOX-BM series | 62.5/125 μm or 50/125 μ Fiber Type m multimode fiber
PHOX-BL series | 9/125 μm single mode fiber | |||
一般电气特性 | ||||
输入电压 | DC5 ~ 24 V | |||
电源电流 | 300 mA @12V each module | |||
典型功耗 | 3.6 W each module | |||
操作温度 | 0 ~ 60oC (non-condensing) | |||
连接器类型 | Switchcraft TA3F locking connector | |||
约重(单个模块) | 310 gram |
盈美智Vivid LVDS/RS-422 to Camera Link Translators
盈美智 Vivid Camera Link Simulators
盈美智 Vivid Camera Link Breakout Box
盈美智 SVS HR系列相机
盈美智 SVS SVCam-CF系列工业相机
