盈美智 Bitflow Alta-AN图像采集卡
x4 PCI Express; Supports up to four analog cameras
产品分类:机器视觉 图像采集卡
品牌:盈美智
x4 PCI Express "short" card
Super high quality discrete Analog Front End
Three A-to-Ds per VFG (maximum clock rate: 160 MHz)
Supports VGA, SVGA, XGA, SXGA, UXGA resolutions and beyond
Per channel programmable Gain/offset
Supports single tap and dual tap monochrome cameras
Supports RGB cameras (24 bits/pixel)
Supports component YPbPr cameras (YUV 4:4:4)
Supports asynchronous reset cameras
Supports partial scan cameras (high frame rates)
Multiplex between two one-tap or two two-tap cameras
Programmable Region of Interest (ROI) via sub-windowing acquisition
External hardware or software trigger
Acquire at any frame rate
Supports cameras up to 16K x 16K
Supports interlaced and progressive scan cameras
HD/VD/Composite sync signals in/out
Supports WEN input signal
Strobe output (programmable timing)
Provides power to camera (12 V @ 0.5 A)
Flowthru technology, no on-board frame buffers, zero latency data access
Efficient interrupt driven architecture, no software polling required
RoHS compliant
盈美智Vivid LVDS/RS-422 to Camera Link Translators
盈美智 Vivid Camera Link Simulators
盈美智 Vivid Camera Link Breakout Box
盈美智 SVS HR系列相机
盈美智 SVS SVCam-CF系列工业相机
