盈美智 Bitflow Karbon-CXP图像采集卡
PCI Express x8接口 高达135米的电缆长度的支持
产品分类:机器视觉 图像采集卡
品牌:盈美智
Half-Size x8 PCI Express Board
CoaXPress 1.0 compliant
Supports one to four CXP cameras
Supports multi-link CXP cameras (up to four CXP links)
Supports CXP speeds from 1.250 to 6.250 Gb/S
Provides power for all cameras (up to 13 Watts per camera)
Provides Safe Power, full protection from all power line faults
Cameras are Plug and Play with automatic link speed detection
Cable lengths of up to 135 meters are supported
Cameras can be accurately synchronized, or can be completely unsynchronized
PCI Express x8 interface (also works in x16 slots)
Separate I/O for each camera
Highly deterministic, low latency frame grabber to camera trigger
Supports simultaneous serial communications to all cameras
Windows "sees" a separate frame grabber for each camera
FlowThru technology means no on-board memory is needed
Acquire variable length frames from line scan cameras
Acquire image sequences well beyond the 4GB barrier
No frame rate limit
Triggers and encoders for external control of acquisition
Programmable signal generator for camera control (independent for each camera)
Quadrature encoder support including sophisticated triggering schemes
Encoder divider/multiplier
Drivers, utilities and examples for Windows XP/Vista/Windows 7
Supports both 32-bit and 64-bit platforms
Drivers for most 3rd party processing environments (e.g. HALCON, LabView, VisionPro, MATLAB, etc.)
Full GenICam support for control and capture
All models are "half size" PCIe cards
RoHS compliant
盈美智Vivid LVDS/RS-422 to Camera Link Translators
盈美智 Vivid Camera Link Simulators
盈美智 Vivid Camera Link Breakout Box
盈美智 SVS HR系列相机
盈美智 SVS SVCam-CF系列工业相机
