产品选型
Bitflow NEON-CLQ图像采集卡
x4 PCI Express; Supports four Base CL cameras;PoCL
产品分类:
机器视觉 图像采集卡
品牌:
BitFlow
  • Supports four Base CL cameras
  • Provides Power over Camera Link (PoCL) for all cameras
  • Support both PoCL and non-PoCL cameras
  • Provides Safe Power - full protection from all CL power line faults
  • All cameras can be independently synchronized
  • Separate I/O for each camera
  • Support simultaneous serial communications to all four camera
  • The Neon-CLQ appears to Windows as four separate frame grabbers
  • Fully backwards compatible with non-PoCL cameras and cables
  • Half-Size x4 PCI Express Board
  • Acquire up to 24 bits at 85 MHz
  • FlowThru technology means that no on-board memory is needed
  • Supports images up to 256K x 128K
  • No frame rate limit
  • Triggers and encoders for external control of acquisition
  • Programmable signal generator for camera control (independent for each camera)
  • Quadrature encoder support including sophisticated triggering schemes
  • Encoder divider/multiplier
  • Drivers, utilities and examples for Windows XP/2003/Vista/Windows 7
  • Supported on both 32-bit and 64-bit platforms
  • Drivers for most 3rd party processing environments
  • Acquire variable length frames with line scan cameras
  • Acquire image sequences well beyond the 4GB barrier
  • RoHS compliant
盈美智Vivid LVDS/RS-422 to Camera Link Translators
盈美智 Vivid Camera Link Simulators
盈美智 Vivid Camera Link Breakout Box
盈美智 SVS HR系列相机
盈美智 SVS SVCam-CF系列工业相机
