Phoenix系列支持CoaXPress, HD-SDI, SDI, Camera Link (including PoCL/SafePower support) and LVDS 相机
产品分类:
机器视觉 图像采集卡
品牌:
盈美智
The powerful Phoenix series has supportfor
CoaXPress, HD-SDI, SDI, Camera Link (including PoCL/SafePower support) and LVDScameras. Available for several operating systems and form factors (PCI Express,PCI 64-bit/66MHz, PCI 32-bit/33MHz, PMC, PC/104-Plus, PCI/104-Express &cPCI)
| PHX-CXP in x4 PCI Express Form Factor A four lane (x4) PCI Express board for capture from CoaXPress (CXP) cameras. CoaXPress is an asymmetric high speed point to point serial communication standard for the transmission of video and still images, scalable over single or multiple coaxial cables.
| PHX-CXP in x1 PCI Express Form Factor A four lane (x1) PCI Express board for capture from CoaXPress (CXP) cameras. CoaXPress is an asymmetric high speed point to point serial communication standard for the transmission of video and still images, scalable over single or multiple coaxial cables. |
| PHX-D64CL in x4 PCI Express Form Factor A four lane (x4) PCI Express board for capture from Base, Medium or Full Camera Link cameras. A high performance board with the bandwidth and features to cope with today's high end cameras. Supports Power over Camera Link (PoCL) and SafePower. |
| PHX-D48CL in x4 PCI Express Form Factor A four lane (x4) PCI Express board for capture from Base, dual Base or Medium Camera Link cameras. A high performance board with the bandwidth and features to cope with today's high end cameras. Supports Power over Camera Link (PoCL) and SafePower. |
| PHX-D48CL in x1 PCI Express Form Factor A single lane (x1) PCI Express board for capture from Base, dual Base or Medium Camera Link cameras. Designed to be low cost yet with features to cope with more demanding applications. Supports Power over Camera Link (PoCL) and SafePower. |
| PHX-D24CL in x1 PCI Express Form Factor A single lane (x1) PCI Express board for capture from a single Base Camera Link camera. Affordable yet with extra bandwidth and features to cope with today's more demanding cameras. Supports Power over Camera Link (PoCL) and SafePower. |
| PHX-D48CL in 64-bit/66MHz PCI Form Factor A 64-bit/66MHz PCI board, also supporting PCI-X, for capture from Base, dual Base or Medium Camera Link cameras. This high performance board is designed for demanding image capture applications where PCI Express is not appropriate. |
| PHX-D24CL in 32-bit/33MHz PCI Form Factor An entry level 32 bit PCI board for capture from a single Base Camera Link camera. Designed to be low cost yet functional with extensive onboard I/O. |
| PHX-D48CL in 64-bit/66MHz cPCI Form Factor A high end industrial embedded form factor board for capture from Base, dual base or Medium Camera Link cameras. CompactPCI is an embedded form factor typically used in industrial, aerospace and other embedded systems, and this board is in the 6U size. |
| PHX-D48CL in 32-bit/66MHz cPCI Form Factor A high end industrial embedded form factor board for capture from Base, dual base or Medium Camera Link cameras. This is available as a conduction cooled board for demanding applications. CompactPCI is an embedded form factor typically used in industrial, aerospace and other embedded systems, and this board is in the 3U size. |
| PHX-D24CL in 32-bit/33MHz PMC Form Factor A high end industrial embedded form factor board for capture from a single Base Camera Link camera. PMC is used as a mezzanine board in 3U & 6U rack systems, such as CompactPCI and VME. |
| PHX-D48CL in PCI/104-Express Form Factor An industrial embedded form factor board for capture from a single Base, dual Base or Medium Camera Link cameras. It uses the PCI Express extension to the well established PC/104-Plus standard. It offers the flexibility of the Camera Link interface in a truly embedded and rugged form factor. Supports Power over Camera Link (PoCL) and SafePower. |
| PHX-D24CL in PC/104-Plus Form Factor An industrial embedded form factor board for capture from a single Base Camera Link camera. It uses the PCI extension to the well established PC/104 standard. It offers the flexibility of the Camera Link interface in a truly embedded and rugged form factor. |
| PHX-D20HDSDI in x4 PCI Express Form Factor A four lane (x4) PCI Express board for capture from uncompressed 8-bit and 10-bit HD-SDI and standard definition SDI cameras. A high performance board with multi channel capability allowing simultaneous capture from two independent HD-SDI or SDI cameras. Supports 525 NTSC, 625 PAL, 720p and 1080i; SMTPE 292M, SMPTE 344M, and SMPTE 259M. |
| PHX-D10HDSDI in x4 PCI Express Form Factor A four lane (x4) PCI Express board for capture from uncompressed 8-bit and 10-bit HD-SDI and standard definition SDI cameras. A high performance board with a single input channel. Supports 525 NTSC, 625 PAL, 720p and 1080i; SMTPE 292M, SMPTE 344M and SMPTE 259M. |
| PHX-D20HDSDI in x1 PCI Express Form Factor A single lane (x1) PCI Express board for capture from uncompressed 8-bit and 10-bit HD-SDI and standard definition SDI cameras. Multi channel capability allows simultaneous capture from two independent SDI cameras, or to switch between two HD-SDI cameras. Supports 525 NTSC, 625 PAL, 720p and 1080i; SMTPE 292M, SMPTE 344M and SMPTE 259M. |
| PHX-D10HDSDI in x1 PCI Express Form Factor A single lane (x1) PCI Express board for capture from uncompressed 8-bit and 10-bit HD-SDI and standard definition SDI cameras. Designed for entry level applications this board has a single input channel. Supports 525 NTSC, 625 PAL, 720p and 1080i; SMTPE 292M, SMPTE 344M and SMPTE 259M. |
| PHX-D36 in x1 PCI Express Form Factor A single lane (x1) PCI Express board for capture from LVDS and RS-422 camera sources with a maximum bit depth of 36-bits. There is extensive onboard I/O along with serial port functionality. |
| PHX-D36 in 64-bit/66MHz PCI Form Factor A 64-bit/66MHz PCI board, also supporting PCI-X, for capture from LVDS and RS-422 camera sources with a maximum bit depth of 36-bits. This high performance board is designed for demanding image capture applications where PCI Express is not appropriate. |
| PHX-D36 in 32-bit/33MHz PCI Form Factor An entry level 32 bit PCI board for capture from LVDS and RS-422 camera sources with a maximum bit depth of 36-bits. There is extensive onboard I/O along with serial port functionality. |
