宜鼎国际2.5" SATA SSD 3IE4固态硬盘
产品分类:工控机 工控机配件 存储产品
品牌:宜鼎国际
Features
2.5” SATA III solution for industrial field
7mm height mechinicial design
DRAM-less, high-level data integrity
L³ architecture extends lifespan
Excellent IOPS boosts system performance
Built-in thermal sensor
Support S.M.A.R.T, TRIM, NCQ and iData Guard
Overview
Innodisk 2.5” SATA SSD 3IE4 is characterized by L³ architecture with the latest SATA III (6.0GHz) Marvell NAND controller. Innodisk’s exclusive L³ architecture is L² architecture multiplied LDPC (Low Density Parity Check). L² (Long Life) architecture is a 4K mapping algorithm that reduces WAF and features a real-time wear leveling algorithm to provide high performance and prolong lifespan with exceptional reliability.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
