宜鼎国际SATADOM™-SL 3ME4电子硬盘
产品分类:工控元器件 工控机 工控机配件 存储器 固态电子盘 存储产品
品牌:宜鼎国际
Features
SATA III solution for industrial field
Exclusive L³ architecture
DRAM-less, 100% data integrity
Excellent random performance
Designed with hardware LDPC ECC engine
Built-in Pin 8 power supply
Overview
Innodisk SATADOM-SL 3ME4 is characterized by L³ architecture with the latest SATA III(6.0GHz) Marvell NAND controller. Innodisk’s exclusive L³ architectureis L² architecture multiplied LDPC (Low Density Parity Check). L² (Long Life) architecture is a 4K mapping algorithm that reduces WAF andfeatures a real-time wear leveling algorithm to provide high performance and prolong lifespan with exceptional reliability.
Innodisk SATADOM-SL 3ME4 is designed for industrial field, and supports several standard features, including TRIM, NCQ, and S.M.A.R.T. In addition, Innodisk’s exclusive industrial-oriented firmware provides a flexible customization service, making itperfect for a variety of industrial applications.
The innovative Pin 8 uses the SATA connector itself as a power supply to drive the device without external cables. It could be connected directly to the SATA on-board socket on customer’s system without additional power cable. Besides, the booting time for operation and the power consumption is less than hard disk drive (HDD), and can work under harsh environmentcompile with ATA protocol, no additional drives are required, and theSSD can be configured as a boot device or data storage device.
Specifications
宜鼎国际 EMPL-22S2工控周边扩展卡
宜鼎国际 EMPL-22S1工控周边扩展卡
宜鼎国际 EMPL-22N1工控周边扩展卡
宜鼎国际 EMPL-21S2工控周边扩展卡
