宜鼎国际nanoSSD 3IE3电子盘
nanoSSD 3IE3
产品分类:工控元器件 工控机 工控机配件 存储器 固态电子盘 存储产品
品牌:宜鼎国际
Features
Compliant with JEDEC MO-276 Specification
SATA III 6Gbps
Supports NCQ
Intelligent Flash management & real time garbage collection
Supports S.M.A.R.T, and iSMART utility
Zero mechanical interference
Overview
Innodisk nanoSSD is an integrated SATA storage device; it offers highperformance, light weight, low power consumption and cost efficiency in a JEDEC MO-276(μSSD) standard form factor. The nanoSSD combines with SATA III Flash controller, making it a great solution for a wide range embedded system, thin PC, automotive device, medical equipment and most industrial applications.
nanoSSD also comes with industrial level firmware design for extreme environments as well as the possibility for customized firmware to enhance the fitness in different applications.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
