宜鼎国际mSATA 3IE2-P固态硬盘
产品分类:工控元器件 工控机 工控机配件 存储器 固态电子盘 存储产品
品牌:宜鼎国际
Features
Exclusive iSLC FW architecture
SATA 6.0 Gb/s interface
JEDEC MO-300 standard dimension
High IOPS by on-board DRAM design
Intelligent error recovery system
iSMART disk health monitoring
iData Guard for abnormal power failure
Zero mechanical interference
DEVSLP supported
Overview
Innodisk mSATA 3IE2-P is SATA III 6Gb/s flash based disk, which delivers excellent performance, especially in random data transfer rate, and which offers reliability making it the ideal solution for a variety of applications,including embedded system, industrial computing, and enterprise field. 3IE2-P mSATA not only performs unmatched performance, but also designed with Innodisk owned technical knowhow such as iData Guard to ensure the data integrity and highest levels of reliability. Featuring L² architecture, the life span of the SSD is maximized by an evolved wearleveling algorithm.
Specifications
宜鼎国际首创InnoEx虚拟I/O扩充模块 实现敏捷部署 推动AI应用高效落地
宜鼎InnoOSR一鍵還原固態硬盘
宜鼎国际DDR5 WT ECC UDIMM工业用闪存模块
宜鼎国际DDR5 WT ECC SODIMM工业用闪存模块
宜鼎国际DDR5 WT RDIMM工业用闪存模块
